RLP Hydra - Signal Generator
The following is an RLP implementation of a Signal Generator (aka Output Compare) for the FEZ Hydra. This implementation provides the basic capabilities to generate signals with and without a carrier signal.
The carrier signal support is ideal for generating IR signals which can simulate those used to control your TV or hobby chopter.
In addition you can specify the number of times the signal should be repeated, allowing you to control the number of generated pulses without being required to create a buffer with the repeating timing.
This implementation does not provide support for asynchronous signal generation. For you require asynchronous signal generation on the Hydra you can take a look at the custom Hydra firmware in which I provide a drop in replacement for the SignalGenerator available as part of the Premium libraries for boards like the FEZ Spider, G120 and Cobra II.
http://www.tinyclr.com/forum/topic?id=10126
Note: The zip contains a SDK folder which include the fully compiled assemblies with the RLP code already hosted. Using this you will not be required to compile the RLP code yourself.
