Modlab DSLR Remote Module Driver
This is the driver for the DSLR remote module made.
This driver supports 4.1 and 4.2 Gadgeteer and allows you to specify a delay between focus and shutter fire to allow for Auto Focus lenses to focus properly.
The module itself has a 2.5mm jack socket. the center pin is shutter, middle pin is focus and rear pin is ground. Its designed primarily to use a camera axe cable but you can always make your own.
This module is great for time lapse photography or maybe hook up a pir and take wildlife shots when an animal comes close to your camera.
