Hmmm… Trying to run it in my emulator and getting out of memory exception. Did you try to run it in an emulator? (Ignore all “unsupported” exceptions during startup)
I have one suggestion for improvement. Microsoft.SPOT.TinyCore is one of the “expensive” assemblies to use. You only reference it for EventHandler delegate. I would define my own delegate and would remove the reference completely.
@ Architect - I have not tried it on the emulator, I will give that a shot and see how it goes. Thanks for the tip on the Microsoft.SPOT.TinyCore, I will look at removing that… Going to download your emulator now.
@ Architect - I just tried running it in the emulator, but the emulator crashes with an Access Violation, there is no useful stacktrace info, I will probably need to get the code for the core emulator libraries and trace into that.
I will look into it, but just thought I would mention it in case you have faced this before. Btw. this is after ignoring all the NotSupportedExceptions.
I had that change locally as well, but still getting out of memory exception and then Access Violation in the emulator. I assume access violation is a side effect of the out of memory exception.
