Extensible Command Language (Command Shell) for the Cerb40
Inspired by FEZTerm (http://www.tinyclr.com/forum/topic?id=8118), this “command shell” is easily extensible and comes with a few example functions to get you going:
Overview:
The GMD STM32F4 Command Shell, “GMD Command Shell”, or simply “Shell” is an interface that allows “terminal” access to methods run on the Cerb40. For example, type ‘help’ in the terminal, and a list of commands and their descriptions will be returned.
The program should easily port to other boards in the Cerberus family, if any porting is necessary. No boards other than the Cerb40 have been tested.
Rather than accepting raw text commands, the Shell employs a messaging system that encompasses message metadata as well as the command and any parameters. Results are similarly structured. The included “terminal” program, GMDTerm, a C# Windows app, wraps commands in messages and unwraps results and displays the results, if any. The Shell is designed to use by any application, not just the terminal. The current incarnation is a synchronous implementation, but the Shell does provide for asynchronous messaging. GMDTerm does not listen for asynchronous messages, but the functionality could be incorporated into any app using the Shell, including GMDTerm.
Communication is over UART, or optionally, RS-232, depending upon hardware setup, using COM2 of the Cerb. Data rates of 460800 baud have been used without issue so far. The UART settings of the Cerb are hardcoded, while GMDTerm takes command line parameters for the communication setttings.
Hardware:
It is not essential to use COM2 of the Cerb, any UART will do, as will any parity, data bit, and stop bit settings. Simply modify the settings in the Main() method of Program.cs and start GMDTerm with matching settings. The programs were developed using a USB to TTL cable to provide a virtual COM port on the PC side that can directly connect to the Cerb’s TTL UART. Using a level converter and using RS-232 connected to a PC serial port is perfectly acceptable.
Messaging Specifics:
The messaging system employed by the shell is designed to provide a robust interface between the Cerb and it’s consumer app. A “terminal” program is provided, but the messaging is more robust than a simple command line interface in that it provides metadata beyond the command line. Messages, and Results, are transmitted with specific begin and end tags to help ensure message completion. A message length is also included to help determine message completion. A sequence number is included in the message to identify it, useful for detecting duplicated messages, and this sequence number is returned in the result to identify the originating message. Additionally, a callback ID in the message allows the caller to identify the handler for the
result, as the result will also contain the callback ID. The rest of the message payload consists of the command and any parameters.
Results are similarly structured in that they contain a length, sequence number, and callback ID. Additionally, they contain a ResultCode, indicating the outcome of the call, e.g. Success. Results also contain a ResultType to indicate the type of data being returned. See MessagingObjects.cs in the project GMD.STM32F4.CmdShell.Messaging for a list of data types supported in this first release. Finally, Results may contain data of the type designated by the ResultType byte.
Command Handlers:
A command handler is a class that implements the IMessageHandler interface. This interface defines the methods used to interact with the main Shell methods for handling commands from GMDTerm, or any other app written to connect to the Shell. An IMessageHandler provides one or more CmdHandlerDef objects to the
parent, defining the commands handled, the method that handles it, and a text help string that is returned when the “help” command is received. See the file IMessageHandler.cs in GMD.STM32F4.CmdShell.Messaging for more detailed info, or see one of the objects below for an example of implementation.
Three command handlers are provided in this release. They provide examples of system commands, I/O commands, and Random Number Generator commands.
SysCmdHandler:
Provides "system" commands, and is therefore included in the main Shell executable. It provides for the following commands:
ping - request an acknowledgement from the Shell
help (also ? or h) - provide help for all commands, or a specific one
if provided as a parameter
version (also ver) - return the Shell version
time - return the Shell time, or set it if given as a parameter
date - return the Shell date, or set it if given as a parameter
info - display system info
shutdown - shutdown the Shell application
reboot - reboot the device
GPIO Handler:
Provides commands for controlling GPIO on the Cerb, currently 16 digital in
and 16 digital out:
read - return all input states
set - set all output states (requires parameter)
readinput (also ri) - return the state of a specific input pin
setoutput (also so) - set the state of a specific output pin
getpinmap - get a mapping of pin numbers to device pins
RNG Handler:
Provides command to retrieve a random number generated by the hardware RNG
on the Cerb. It currently has one command:
getrnd - return a random UInt
Custom Handlers:
Commands and handlers can be defined for almost any operation. Operations
need not be synchronous. As long as the consumer app is prepared for the
asynchronous result, results can be passed back periodically, on an event,
an interrupt, a completion, or any other trigger. For example, a result
could be sent in response to an digital input signal on the Cerb, or when
an analog signal reaches a certain threshold. Operations can be on-demand
or long running. Custom handlers allow the developer to have real-time
interaction with their device either through a terminal or programatically
with ease.
Terminal Commands:
The following commands are intercepted by GMDTerm and are not passed on
to the device:
exit (also close or quit) - close the terminal
disconnect - close the port to the device
connect - open and initialize the connection to the device
Notes:
Currently, PC0 is not available for output, it is being used for a
diagnostic LED to provide feedback when not attached to the debugger.
The device does not seem to receive data after a reboot without the
debugger connected. Running under the debugger works, and data
continues to flow after disconnecting the debugger and even the
debugging USB cable, but rebooting outside the debugger seems to
leave the device unable to listen on COM2.
Future enhancements:
Add USB communications support
Add support for Analog input/output to GPIO Handler.
Handle clock and other errors in RNG
Better handling of message reads
Package:
Solution and Project GMD.STM32F4.CmdShell - The Shell, to install on the
Cerb device. Approximately 54k deployable including provided message
handlers.
Project GMD.STM32F4.CmdShell.Messaging - Contains the messaging objects and
Command Handler interface.
Project GMD.STM32F4.CmdShell.IO - GPIO Command Handler
Project GMD.STM32F4.CmdShell.RNG - RNG Command Handler
Project GMD.STM32F4.Hardware - Hardware addresses, IRQs, Peripherals,
Registers and Pins of the STM32F4 (written for the Discovery board)
Project GMD.STM32F4.RNG - An interface to the hardware RNG on the STM32F4
Solution and Project GMDTerm - .NET "Terminal" program to interact with
the Shell textually.
