Cerb40 Digital Input Output Demo
This demonstrate simple input and output capabilities of Cerb40. Output demonstrated by assigning output port to LED’s that control the turn ON and OFF thru transistor. One output demo is a simple running light LED that turn ON and OFF the LED’s in sequence. The other output demo is combination of several sequences in which each sequence consist of different pattern of LED lights. The next demo is on the input using button and input source thru inverting Schmitt Trigger. Input is demonstrated with InputPort and InterruptPort. Each button is assigned to a specific LED’s and possible to assigned to any combination of LED’s.
