I have all the updated drivers and all the cables are connected to my computer. So i am trying to run a test program that looks like this:
namespace GadgeteerApp2
public partial class Program
OutputPort LED;
LED = new OutputPort((Cpu.Pin)75, true);
Debug.Print(“Program Started”);
However i am getting an error that says: Device not found or cannot be opened - USB:Gadgeteer.
I don’t think that is the problem. I went and replaced the built in mainboard with the MountaineerEth board but i still get the same error. Unless there is another place that i need to change it at.
the deployment has Transport: USB
and the device shows
I clicked on the drop down box but was the only option. However i typed in “MountaineerEth” but it didn’t do anything. Is the device maybe not installed properly?
Yea i just tried a different USB cable and the power light comes on with either so it isn’t the hub. I’ve tried it in all 4 of the USB ports on my computer as well.
I found a way to reset and reinstall the driver and i also checked the firmware which I had installed but never got implemented apparently so i uninstalled the firmware and reinstalled it and It is fixed and i can chose the mainboard as device under properties. However the code now returns the error that there is something wrong with your hardware. However i think that the issue with that is that the way i initialize the outputport is incorrect. I might switch from gadgeteer to plain vanilla. Do you have a preference either way, all im using are Digital and/or Analog I/O.
