I am using the programmable flash in multiple byte arrays. Each array corresponds to a variable that I want to save. I have reserved 32 bytes per variable and each variable is assign an index. The storage location is therefore index * 32.
I changed the array size to 48 and I get invalid operation. I have also found that after reset or power down/up that some variables (byte arrays) show up as all 0xFF Is there some timing restrictions I need to be aware of ? Is there byte array size restriction ? What is the write/erase cycle maximum ?
We have found a couple of issues with secure storage and it got changed quite a bit to include otp.
Not sure what issue you have but I recommend you wait a couple of days.
Ok, I can still use SD card for now
The size and destination offset need to be multiply of 32, so 48 won’t work.
But the API have changed so you can wait until next release.
When is preview 7 scheduled?
Next week… And it will be a release candidate
Any release notes yet ?
No but you can see the docs and libs repos in GitHub for changes.
