Hello,
I’m working on a little application that uses the tunes module but I’m running into a few problems.
I’ve tried calling in ProgramStarted():
tunes.Play(Tunes.Tone.A4);
tunes.Stop();
The app runs, I hear the correct tone for about half a second then I just get a constant horrible low buzz.
If I add more tones, these play in succession with the horrible low buzz in between and then when they’ve finished I just get the low buzz again.
I’ve tried calling tunes.Stop(); after tunes.Play(); but it doesn’t seem to do anything.
I’ve also tried setting my own duration with tunes.play(int freq, int duration); but it doesn’t seem to make a difference.
Does anyone have any idea why this is happening?
Thanks for your time.
EDIT
After some additional searching I’ve just found this thread: https://www.ghielectronics.com/community/forum/topic?id=17606
I guess I’ll have a go at using the fixed driver.
