That link is not related. Try to make a simple app that you run on device and in emulator. You can also try to get your data into a buffer that you parse later. Assuming there is a problem, we need to know where and how to repro.
The debug output of the ChipworkX-Device (I don’t know how to use the Emulator) - and it’s in German:
Der Thread '<Kein Name>' (0x2) hat mit Code 0 (0x0) geendet.
Waiting for connection...
Got socket connection from: 192.168.1.105:49499
Thanks for any help…
EDIT: OK, the creation of the thread makes some troubles! I can send data to the pc, thats no problem with the NetworkStream. But I have troubles to read data from the NetworkStream. I cannot read any data from there - read always blocks or I get an exception “ResourceTemporarilyUnavailable”
So I just tried to send something (works!) and try to receive some text from java - that does NOT work.
When you deploy to the device, you usually select USB. There is another option fro emulator. That is all you have to do. I am curious of the emulator gives you different results.
Note that the emulator can’t run any GHI libraries but you do not need those in a simple network test.
