Hello every one !
first of all sorry if i made mistake i’m french ^^
So i use code exemple in the ebook " internet of thing", that great but i try to modify a little.
Now i have a problem in the GC => Type 13 (SZARRAY) take more and more space and so the card do not answer …
here is the code :
using System.Text;
using GHIElectronics.NETMF.Net.NetworkInformation;
OutputPort red = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di2, false);
OutputPort green = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di3, false);
OutputPort yellow = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di1, false);
green.Write(false);
string ValeurLedVerte = "allumer";
string LectureLedVerte = "eteint";
yellow.Write(false);
string ValeurLedOrange = "allumer";
string LectureLedOrange = "eteint";
red.Write(false);
string ValeurLedRouge = "allumer";
string LectureLedRouge = "eteint";
PWM piezo = new PWM((PWM.Pin)FEZ_Pin.PWM.Di5);
byte[] ip = { 192, 168, 0, 200 };
byte[] subnet = { 255, 255, 255, 0 };
byte[] gateway = { 192, 168, 1, 1 };
byte[] mac = { 0x00, 0x88, 0x98, 0x90, 0xD4, 0xE0 };
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10, (Cpu.Pin)FEZ_Pin.Digital.Di7, true);
NetworkInterface.EnableStaticIP(ip, subnet, gateway, mac);
NetworkInterface.EnableStaticDns(gateway);
// start server
HttpListener listener = new HttpListener("http", 80);
listener.Start();
HttpListenerResponse response = null;
HttpListenerContext context = null;
HttpListenerRequest request = null;
try
context = listener.GetContext();
response = context.Response;
request = context.Request;
// si un bouton est pressé
if (context.Request.HttpMethod == "POST")
if (request.ContentLength64 > 0)
Debug.GC(true);
// on lis le "name" des bouton + les "value"
byte[] buffer = new byte[(int)request.ContentLength64];
request.InputStream.Read(buffer, 0, (int)request.ContentLength64);
string actionAeffectuer = new string(Encoding.UTF8.GetChars(buffer));
// la variable actionAeffectuer contient "name"="value"
int index = actionAeffectuer.IndexOf('='); // on obtient la place de "="
actionAeffectuer = actionAeffectuer.Substring(0, index); // on découpe la variable actionAeffectuer pour ne récuperer tout ce qu'il y a avant le "="
//et maintenant on peut tester l'action a effectuer !!
if (actionAeffectuer == "volet")
if (green.Read() == true)
green.Write(false);
green.Write(true);
ValeurLedVerte = "eteindre";
LectureLedVerte = "allumer";
if (actionAeffectuer == "porte")
if (yellow.Read() == true)
yellow.Write(true);
ValeurLedOrange = "eteindre";
LectureLedOrange = "allumer";
if (actionAeffectuer == "heat")
if (red.Read() == true)
red.Write(false);
red.Write(true);
ValeurLedRouge = "eteindre";
LectureLedRouge = "allumer";
/* buffer = null;*/
// Sends response
response.StatusCode = (int)HttpStatusCode.OK;
byte[] HTML = Encoding.UTF8.GetBytes(
"<html><body>" +
"<h1>Hosted on FEZ Panda II</h1>" +
"<form action=\"\" method=\"post\">" +
"<p>led verte :<input type=\"submit\" name=\"volet\" value=\"" + ValeurLedVerte + "\"> la led est actuellement " + LectureLedVerte + ".</p>" +
"<p>led orange :<input type=\"submit\" name=\"porte\" value=\"" + ValeurLedOrange + "\"> la led est actuellement " + LectureLedOrange + ".</p>" +
"<p>led rouge :<input type=\"submit\" name=\"heat\" value=\"" + ValeurLedRouge + "\"> la led est actuellement " + LectureLedRouge + ".</p>" +
"</form>" +
"</body></html>");
response.ContentType = "text/html";
response.OutputStream.Write(HTML, 0, HTML.Length);
response.Close();
/* ValeurLedVerte = null;
ValeurLedOrange = null;
ValeurLedRouge = null;
LectureLedVerte = null;
LectureLedOrange = null;
LectureLedRouge = null;*/
/* response = null;
context = null;
request = null;*/
catch
if (context != null)
context.Close();
and here is a sample of the error
GC: 3msec 30084 bytes used, 34296 bytes available
Type 0F (STRING ): 1260 bytes
Type 11 (CLASS ): 4416 bytes
Type 12 (VALUETYPE ): 600 bytes
Type 13 (SZARRAY ): 3120 bytes
Type 15 (FREEBLOCK ): 34296 bytes
Type 16 (CACHEDBLOCK ): 72 bytes
Type 17 (ASSEMBLY ): 15240 bytes
Type 18 (WEAKCLASS ): 48 bytes
Type 19 (REFLECTION ): 24 bytes
Type 1B (DELEGATE_HEAD ): 252 bytes
Type 1D (OBJECT_TO_EVENT ): 168 bytes
Type 1E (BINARY_BLOB_HEAD ): 156 bytes
Type 1F (THREAD ): 384 bytes
Type 20 (SUBTHREAD ): 48 bytes
Type 21 (STACK_FRAME ): 2076 bytes
Type 22 (TIMER_HEAD ): 72 bytes
Type 27 (FINALIZER_HEAD ): 312 bytes
Type 31 (IO_PORT ): 216 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 1548 bytes
GC: 3msec 32220 bytes used, 32160 bytes available
Type 0F (STRING ): 1644 bytes
Type 11 (CLASS ): 5424 bytes
Type 12 (VALUETYPE ): 528 bytes
Type 13 (SZARRAY ): 4776 bytes
Type 15 (FREEBLOCK ): 32160 bytes
Type 1B (DELEGATE_HEAD ): 288 bytes
Type 21 (STACK_FRAME ): 1224 bytes
Type 27 (FINALIZER_HEAD ): 360 bytes
GC: 3msec 31404 bytes used, 32976 bytes available
Type 0F (STRING ): 1536 bytes
Type 11 (CLASS ): 5460 bytes
Type 13 (SZARRAY ): 4608 bytes
Type 15 (FREEBLOCK ): 32976 bytes
Type 21 (STACK_FRAME ): 648 bytes
GC: 3msec 34704 bytes used, 29676 bytes available
Type 0F (STRING ): 1440 bytes
Type 11 (CLASS ): 6108 bytes
Type 13 (SZARRAY ): 6120 bytes
Type 15 (FREEBLOCK ): 29676 bytes
Type 21 (STACK_FRAME ): 1836 bytes
Type 27 (FINALIZER_HEAD ): 408 bytes
GC: 3msec 33744 bytes used, 30636 bytes available
Type 0F (STRING ): 1560 bytes
Type 11 (CLASS ): 6252 bytes
Type 13 (SZARRAY ): 6084 bytes
Type 15 (FREEBLOCK ): 30636 bytes
GC: 3msec 36912 bytes used, 27468 bytes available
Type 0F (STRING ): 1296 bytes
Type 11 (CLASS ): 6864 bytes
Type 13 (SZARRAY ): 7740 bytes
Type 15 (FREEBLOCK ): 27468 bytes
Type 21 (STACK_FRAME ): 1764 bytes
Type 27 (FINALIZER_HEAD ): 456 bytes
GC: 3msec 36036 bytes used, 28344 bytes available
Type 11 (CLASS ): 7044 bytes
Type 13 (SZARRAY ): 7536 bytes
Type 15 (FREEBLOCK ): 28344 bytes
GC: 3msec 38328 bytes used, 26052 bytes available
Type 0F (STRING ): 1248 bytes
Type 11 (CLASS ): 7584 bytes
Type 13 (SZARRAY ): 8976 bytes
Type 15 (FREEBLOCK ): 26052 bytes
Type 27 (FINALIZER_HEAD ): 504 bytes
GC: 3msec 38316 bytes used, 26064 bytes available
Type 11 (CLASS ): 7836 bytes
Type 15 (FREEBLOCK ): 26064 bytes
GC: 3msec 40248 bytes used, 24132 bytes available
Type 0F (STRING ): 1020 bytes
Type 11 (CLASS ): 8340 bytes
Type 13 (SZARRAY ): 10320 bytes
Type 15 (FREEBLOCK ): 24132 bytes
Type 27 (FINALIZER_HEAD ): 552 bytes
GC: 3msec 40596 bytes used, 23784 bytes available
Type 11 (CLASS ): 8628 bytes
Type 13 (SZARRAY ): 10416 bytes
Type 15 (FREEBLOCK ): 23784 bytes
GC: 3msec 42420 bytes used, 21960 bytes available
Type 0F (STRING ): 828 bytes
Type 11 (CLASS ): 9024 bytes
Type 13 (SZARRAY ): 11748 bytes
Type 15 (FREEBLOCK ): 21960 bytes
Type 21 (STACK_FRAME ): 1428 bytes
Type 27 (FINALIZER_HEAD ): 600 bytes
GC: 3msec 42864 bytes used, 21516 bytes available
Type 11 (CLASS ): 9420 bytes
Type 13 (SZARRAY ): 11844 bytes
Type 15 (FREEBLOCK ): 21516 bytes
GC: 3msec 43008 bytes used, 21372 bytes available
Type 0F (STRING ): 552 bytes
Type 11 (CLASS ): 9264 bytes
Type 13 (SZARRAY ): 12960 bytes
Type 15 (FREEBLOCK ): 21372 bytes
Type 21 (STACK_FRAME ): 852 bytes
Type 27 (FINALIZER_HEAD ): 624 bytes
GC: 3msec 45144 bytes used, 19236 bytes available
Type 11 (CLASS ): 10212 bytes
Type 13 (SZARRAY ): 13284 bytes
Type 15 (FREEBLOCK ): 19236 bytes
Type 27 (FINALIZER_HEAD ): 648 bytes
GC: 3msec 46356 bytes used, 18024 bytes available
Type 0F (STRING ): 1272 bytes
Type 11 (CLASS ): 10440 bytes
Type 13 (SZARRAY ): 13956 bytes
Type 15 (FREEBLOCK ): 18024 bytes
Type 21 (STACK_FRAME ): 1260 bytes
Type 27 (FINALIZER_HEAD ): 672 bytes
and after that ( you can see that szarray grow up) :
Exception System.OutOfMemoryException - CLR_E_OUT_OF_MEMORY (1)
#### Message:
#### GHIElectronics.NETMF.Net.W5100::RegisterRead [IP: 0014] ####
#### GHIElectronics.NETMF.Net.W5100::getSn_RX_RSR [IP: 000a] ####
#### GHIElectronics.NETMF.Net.SocketNative::poll [IP: 0053] ####
#### GHIElectronics.NETMF.Net.SocketNative::recv [IP: 000c] ####
#### GHIElectronics.NETMF.Net.Sockets.Socket::Receive [IP: 0029] ####
#### GHIElectronics.NETMF.Net.Sockets.NetworkStream::Read [IP: 004d] ####
#### GHIElectronics.NETMF.Net.InputNetworkStreamWrapper::RefillInternalBuffer [IP: 0038] ####
#### GHIElectronics.NETMF.Net.InputNetworkStreamWrapper::Read_HTTP_Line [IP: 004b] ####
#### GHIElectronics.NETMF.Net.InputNetworkStreamWrapper::Read_HTTP_Header [IP: 0005] ####
#### GHIElectronics.NETMF.Net.HttpListenerRequest::ParseHTTPRequest [IP: 0170] ####
#### GHIElectronics.NETMF.Net.HttpListenerContext::get_Response [IP: 000d] ####
#### Program::Main [IP: 00cd] ####
I know that there is a lot of thing to read …
So thank you!
