Hello,
I have a small problem with a timer, because I want to send information (ReqGet()) every 50 seconds, but the function "timer_Tick " doesn’t work.
As soon as you have an idea ?
namespace Wifi
public partial class Program
GT.Timer timer = new GT.Timer(30000, GT.Timer.BehaviorType.RunContinuously);
if (Startwifi())
if (testReq())
timer.Start();
//Thread.Sleep(Timeout.Infinite);
private void timer_Tick(GT.Timer timer)
ReqGet();
bool testReq()
HttpWebResponse response;
HttpWebRequest request;
Debug.Print("Generating Request");
request = (HttpWebRequest)HttpWebRequest.Create("http://google.ch");
request.Method = "GET";
request.UserAgent = "MyApp NETMF";
request.KeepAlive = false;
request.Timeout = 1000;
Debug.Print("Awaiting response...");
response = (HttpWebResponse)request.GetResponse();
Debug.Print("Done.\n" + response.ContentLength.ToString() + " bytes");
if (response.ContentLength > 0)
return true;
return false;
bool Startwifi()
if (wifi_RS21 != null)
if (wifi_RS21.Interface.IsOpen)
wifi_RS21.Interface.Disconnect();
string SSID = "SGC";
string password = "TechCFPT_2012";
bool conn = false;
wifi_RS21.Interface.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(wifi_RS21.Interface);
WiFiNetworkInfo[] infos = wifi_RS21.Interface.Scan();
foreach (WiFiNetworkInfo info in infos)
if (info.SSID == SSID)
wifi_RS21.Interface.NetworkInterface.EnableDhcp();
wifi_RS21.Interface.Join(info, password);
Debug.Print(SSID + " Connected");
conn = true;
break;
conn = false;
Debug.Print(SSID + " not found");
return conn;
void ReqGet()
string finalUri = "http://albentrix.com/fez.php?value=20";
HttpWebRequest request = (HttpWebRequest)HttpWebRequest.Create(finalUri);
WebResponse resp = null;
try
resp = request.GetResponse();
catch (Exception e)
Debug.Print("Exception in HttpWebRequest.GetResponse(): " + e.ToString());
if (resp != null)
Debug.Print("ReqOK");
