Hello.
I have a problem with the serial port. I tried an UsbSerial and a RS232 module but the problem is equal.
I need to use it with 7bits datas, parity even, 1stop bit and 9600bps.
I’m using the last sdk on a cerberus mainboard.
Sending datas into with this config works fine but the problem is the following :
When receiving datas (output of method ReadByte() ), the readed bytes MSB are always true, corrupting datas. (read 0x82 instead of 0x02, 0xA0 instead of 0x20,…)
Is this a known problem or do someone have the same problem?
