Problem with piezo
hi
i’m trying to execute this code (from http://www.tinyclr.com/downloads/Component/Broch_Piezo.pdf)
// Create Piezo (speaker) object assigned to the a Peizo Component connected to Di5 with PWM feature
FEZ_Components.Piezo myPiezo = new FEZ_Components.Piezo(FEZ_Pin.PWM.Di5);
// Play a 4kHz. tune for 5 Seconds
myPiezo.Play(4000, 3000);
Thread.Sleep(2000);
// Play sequencial tunes
int[] freq = new int[] { 2000, 3000, 4000, 5000 };
int[] duration = new int[] { 200, 100, 200, 100 };
myPiezo.Play(freq, duration);
Thread.Sleep(1000);
it compiles without errors, but when i try to run it say’s
[quote]The program ‘[5] Micro Framework application: Managed’ has exited with code 0 (0x0).
[/quote]
without doing anything.
any suggestions?
have a nice day
You need to update your firmware and see this too:
http://www.tinyclr.com/forum/1/154/
Also see the big red “ALERT” on the right side on this website :slight_smile:
chimp, I do not think it’s visible enough.
Maybe we should get a big flashing banner! B)
thank your very much
it worked
have a nice day
