I am trying to use infrared sender & receiver library from http://code.tinyclr.com/project/267/infrared-sender-and-receiver/ in order to do some device @ FEZ Mini, but first I wanted to copy&paste the code and the example just to see how it works. The problem is, that something is not ok, because after saving a button code from air-condidioner remote controller, every attempt to control the conditioner with my device was unsuccessful. I made several changes in code to better know what are the differences. So here is the changed OnDataReceived():
private static void OnDataReceived(object sender, uint[] pulseWidths, int pulseCount)
// return if one pulse has been already saved
//if (_savedPulseCount != 0)
// return;
if (_savedPulseCount == pulseCount)
Debug.Print("Pulse counts are equal");
if (_savedPulseCount > 0)
for (int i = 0; i < 16; i++) //just to show some widths
Debug.Print("Saved pulse width: "+_savedPulse[i]+"\tReceived pulse width: "+pulseWidths[i]);
MeasureMeanDifference(_savedPulse, pulseWidths, pulseCount);
_savedPulse = pulseWidths;
_savedPulseCount = pulseCount;
Blink(3);
private static void MeasureMeanDifference(uint[] savedPulse, uint[] pulseWidths, int pulseCount)
int diffSum = 0;
for (int i = 0; i < pulseCount; i++)
var diff = (int)savedPulse[i] - (int)pulseWidths[i];
if (diff < 0)
diff = -diff;
diffSum += diff;
Debug.Print("Total difference is " + diffSum + "us");
Debug.Print("Mean difference is " + (double)diffSum/pulseCount + "us");
And here are the results for TV remote controller Grundig TP720. I used it instead of air-conditioner one because sometimes the beam reaches the device and changing it’s state for several times might be annoying for someone else in the room ;).
Attempts with still pressing a button on the remote control:
[quote]Saved pulse width: 546 Received pulse width: 544
Saved pulse width: 2624 Received pulse width: 2626
Saved pulse width: 537 Received pulse width: 538
Saved pulse width: 510 Received pulse width: 510
Saved pulse width: 491 Received pulse width: 492
Saved pulse width: 574 Received pulse width: 572
Saved pulse width: 499 Received pulse width: 492
Saved pulse width: 557 Received pulse width: 557
Saved pulse width: 496 Received pulse width: 496
Saved pulse width: 560 Received pulse width: 560
Saved pulse width: 493 Received pulse width: 493
Saved pulse width: 563 Received pulse width: 563
Saved pulse width: 500 Received pulse width: 500
Saved pulse width: 556 Received pulse width: 556
Saved pulse width: 497 Received pulse width: 497
Saved pulse width: 559 Received pulse width: 559
Total difference is 17us
Mean difference is 0.80952380952380953us
Total difference is 60us
Mean difference is 2.8571428571428572us
Total difference is 112us
Mean difference is 5.333333333333333us
Total difference is 26us
Mean difference is 1.2380952380952381us
Total difference is 91us
Mean difference is 4.333333333333333us[/quote]
Now I was using the FEZ Mini to generate signal:
[quote]Pulse counts are equal
Saved pulse width: 551 Received pulse width: 570
Saved pulse width: 2618 Received pulse width: 2616
Saved pulse width: 551 Received pulse width: 576
Saved pulse width: 505 Received pulse width: 477
Saved pulse width: 496 Received pulse width: 524
Saved pulse width: 560 Received pulse width: 528
Saved pulse width: 493 Received pulse width: 515
Saved pulse width: 563 Received pulse width: 564
Saved pulse width: 501 Received pulse width: 520
Saved pulse width: 555 Received pulse width: 532
Saved pulse width: 498 Received pulse width: 521
Saved pulse width: 558 Received pulse width: 531
Saved pulse width: 496 Received pulse width: 522
Saved pulse width: 561 Received pulse width: 557
Saved pulse width: 493 Received pulse width: 517
Saved pulse width: 589 Received pulse width: 562
Total difference is 1555us
Mean difference is 23.923076923076923us
Total difference is 1532us
Mean difference is 23.569230769230771us
Total difference is 1370us
Mean difference is 21.076923076923077us
Total difference is 1524us
Mean difference is 23.446153846153845us
Total difference is 1453us
Mean difference is 22.353846153846153us[/quote]
I am using the same IR diode and receiver module (TSOP312) as the author of the library.
Does anyone know (maybe someone had the same issue with this library) what is the possible reason?
Regards,
Tomasz
