Hello. My mountaineer ethernet mainboard suddly stopped being recognized by Windows (I am running windows 7 pro). If I press the reset button, it appears in the devices and printer list for a few seconds, then disappears. I erased the firmware (using the pin1 to 8 on an extender), and was able to reload the firmware with DfuSe demo application. The application says that it successfully loaded the firmware. However, when I reset the mainboard. I does the same thing (shows in the devices and printers for a few seconds, and is gone). Any help would be appreciated.
I doubt it is a power issue, the board has worked fine for weeks. I have tried it on the PC USB ports, and a powered hub, with 2 different USB cables. Same issue. Any other ideas? Thank you.
I loaded the Mountaineer_USB_PK42_QFE2.dfu instead of the ethernet version, and it works. Put the Mountaineer_Eth_PK42_QFE2.dfu firmware back on, and it fails.
@ rmurphy - Did you erase the whole memory and program zone before reinstalling the firmware ?
I had this kind of problem with the board when a program boots and loop in a throw exception constantly…Maybe a trace of a previous exectuable is left in memory…
Sorry, but Im new to this. Im not certain what you mean by erasing the whole memory and program zone. I did the connect pin 1 to 8 on the extender, and pressed the reset button. Then loaded the firmware.
OK. I used MFDeploy to erase the firmware and deployment, and DfuSe to update the firmware (the ethernet version) and the board is working again. Thank you for all of your help.
