So i recently programmed a Tic-Tac-Toe game in C# as a Console App and i wanted to port it to my cerberus and N18 Display. The problem was i needed to change my 2d array to an jagged 2d array , because NetMF doesn’t support multi dimensional arrays and I’m getting a weird exception, because it is exactly the same code, but i only changed the array and the console to my display.
Console Code:
static void Spielfeld()
Console.Clear();
for (int i = 0; i < 2; i++)
Console.Clear();
Console.WriteLine("-------------");
for (int Row = 0; Row < 3; Row++)
for (int Column = 0; Column < 3; Column++)
if (Board[Row, Column] != "X" && Board[Row, Column] != "O")
Board[Row, Column] = " ";
Console.WriteLine("| " + Board[0, Row] + " | " + Board[1, Row] + " | " + Board[2, Row] + " |");
Now the NetMF Code:
void Spielfeld()
uint Position = 5;
display_N18.Clear();
lcdwritetext("-------------", 0,0);
if (Board[Row][Column] != "X" && Board[Row][Column] != "O") /*<-- Here im getting the Exception!*/
Board[Row] [Column] = " ";
lcdwritetext("| " + Board[0][Row] + " | " + Board[1][Row] + " | " + Board[2][Row] + " |", 0,Position);
lcdwritetext("-------------", 0,10);
Position = Position + 5;
Thank you for your help.
