Hi I have a Problem with my Hydra. I will use the MathEx Library from GHI. But When I include the library in my Project I get this Error:
“System.Exception” in Microsoft.SPOT.Hardware.dll "
the Same on my Panda2 works fine! What make I wrong so that I don´t can use this? Is there an other
math library with sin,cos,tan,asin,acos,atan…
thanks for your Help
Here my code:
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using GHIElectronics.OSH.NETMF.Hardware;
using MSpot = Microsoft.SPOT.Hardware;
namespace GadgeteerApp3
public partial class Program
public static MSpot.OutputPort output = new MSpot.OutputPort((MSpot.Cpu.Pin)FEZHydra.Pin.PD11,false);
timer.Tick +=<tab><tab>
timer.Start();
button.ButtonPressed += new Gadgeteer.Modules.GHIElectronics.Button.ButtonEventHandler(button_ButtonPressed);
void button_ButtonPressed(Gadgeteer.Modules.GHIElectronics.Button sender, Gadgeteer.Modules.GHIElectronics.Button.ButtonState state)
while (button.IsPressed)
double d1 = MathEx.Sin(123.543);
double d2 = (234.123 + MathEx.Sqrt(12342.23 - 4 * 123.123 * 123.12)) / 123.23;
double d3 = (234.123 + MathEx.Sqrt(12342.23 - 4 * 123.123 * 123.12)) / 123.23;
double d5 = (234.123 + MathEx.Sqrt(12342.23 - 4 * 123.123 * 123.12)) / 123.23;
output.Write(false);
output.Write(true);
