I have bought your set of development of Cerberus and Cerb 40.
Following supported descrition I installed the developing environment: I filled the linked materials according to (based on) the signed link.
Unfortunatelly I could not manage to fill the most simple program either I used gadgetter template nor using consol (without template).
After downloading code I have received the (error) message:
Create TS.
Loading start at 8036fc8, end 804b620
Assembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)
Assembly: Microsoft.SPOT.Net (4.2.0.0)Assembly: System (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)Loading Deployment Assemblies.
Attaching deployed file.
Assembly: GTM.GHIElectronics.Display_HD44780 (1.0.1.0)Attaching deployed file.
Assembly: GTM.GHIElectronics.Joystick (1.0.1.0)Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0)Attaching deployed file.
Assembly: System.Http (4.2.0.0)Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.3.0)Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCerberus (1.0.6.0)Attaching deployed file.
Assembly: Microsoft.SPOT.Touch (4.2.0.0)Attaching deployed file.
Assembly: GTM.GHIElectronics.LED7R (1.0.0.0)Attaching deployed file.
Assembly: GadgeteerLight (1.0.0.0)Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.2.0.0)Attaching deployed file.
Assembly: System.Net.Security (4.2.0.0)Attaching deployed file.
Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)Attaching deployed file.
Assembly: System.IO (4.2.0.0)Attaching deployed file.
Assembly: GTM.GHIElectronics.MotorControllerL298 (1.0.3.0)Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.2.0.0)Resolving.
Resolve: unknown type: Microsoft.SPOT.Touch.TouchScreenEventHandler
Error: ff000000
Waiting for debug commands...
The program '[2] Micro Framework application: Managed' has exited with code 0 (0x0).
This error exists in the case of Cerebrus and Cerb40 (using updated win8, win7 posready, win7, even table pc and notebook).
I looked after in the internet and I have found an error that is similar to my problem:
http://www.tinyclr.com/forum/topic?id=8368.
I have done the suggested solution, but it did not work. According to the last comment the problem is fixed but it does not seem to me.
Help me pls.
