Hello guys,
im using a FEZ Cerberus board which seems to have Firmaware version 4.2 installed.
The Cerb-Family Updater (v.4.3.) crashes while loading the Firmaware.hex.
Id highly appreciate any advise on how to get this fixed
Thx in advance - Absolute
Thanks for your answer, but I’m still getting an error while deploying the firmware to the mainboard.
Please see the attached image.
It seems like that there is a problem with erasing a certain sector on the mainboard before being able to deploye the file “firmware.hex”.
The same is happening at deploying with MFDeploy.
Notes:
Installed latest FEZ Package (FEZ Config Version 2.0.6) with the latest NETMF 4.3
Started FEZ Config as Administrator
im using VMWare v.4
Any help is appreciated.
There must be a solution.
@ Absolute
Question: Your Developmentmachine with GHI SDK is a Virtual Machine?
Have you tested the update with a other computer (Win7/Win8.1 installed)?
hello,
yes it is a virtual machine and no, no testing on anything else so far.
Can you test it on a real hardware?
May be there is a problem with the virtual USB port.
Mike
March 4, 2015, 6:51am
#7
VM support with the current SDK is much improved but not perfect. If you are having problems loading firmware, try in a real machine.
after loading the firmaware on real machine i can load my code on a VM now. Everything seems to work, thx for the help
