Hi
I am trying to make a pulse counter with this example: [url]http://code.tinyclr.com/project/296/counter-for-fez-domino/[/url]
When starting the project in debug mode i get the following error:
Invalid native checksum: GHIElectronics.NETMF.System 0x74F83809!=0xC032A004
Resolving.
Assembly: FEZ Domino Puls Counter test (1.0.0.0) needs assembly ‘Microsoft.SPOT.Native’ (4.1.2821.0)
Assembly: FEZ Domino Puls Counter test (1.0.0.0) needs assembly ‘GHIElectronics.NETMF.Hardware’ (4.1.5.0)
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) needs assembly ‘Microsoft.SPOT.Native’ (4.1.2821.0)
Error: a3000000
All these assemblys are added as references and i get no compile errors. The only info i have found on this issue so far is that it could be a wrong version in either the FEZ SDK, .NET MF or the FEZ Domino firmware. I have downloaded and installed all this from the GHI site, and as far as i can tell all my versionas are correct.
[b]My FEZ Domino has:
ClrInfo.clrVersion: 4.1.2821.0
ClrInfo.targetFrameworkVersion: 4.1.2821.0
SolutionReleaseInfo.solutionVersion: 4.1.6.0
The NETMF SDK for NETMF v4.1 is SDK Version 1.0.15 (June 30, 2011)
MFDeploy and all the dll’s in \v4.1\Assemblies\le is v4.1.2821.0[/b]
Do any of you have an idea of what i am doing wrong and how to fix it?
