I am working on a weather Datalogger project on EMX tool. My basic requirement is
1 Minute data logging from sensors (attached with RS232 port,)
Store data in SD card after data logging.
Represent read data on GUI.
To achieve this I have made two threads.
Global thread fires every 1 minute
1.1) Communicate with Sensors on RS232
1.2) Get data from sensor and store in global variable.
1.3) Set global variable flag true for other timers indication
1.4) Write data in SD card (csv file)
GUI Representation class level (local) timer fires every 5 second
2.1) Check the global variable flag.
2.2) If it is true then read sensor parameters form global variable and represent in GUI.
2.3) I have used lock mechanism in both the timers while accessing global data.
The application works properly, it collects data from sensors and stores data in csv file of SD card. The problem is consistency. The data logging from sensor and storing in SD card timer (global timer) gets hang after around 9 hours. The GUI timer (local timer) is live when Global timer gets hang.
For testing, I have tried with commenting data storage on SD card and it works properly without hang condition. This means that hang cause because of SD storage. My SD storage class is simple and its AppendStringToFile function writes data in to SD Card. I have made the static object of this class in Global thread class and initialize SD card. In Global thread I am calling AppendStringToFile function for writing.
AppendStringToFile functions code is as under.
public Boolean AppendStringToFile(String stringToWrite,string fname)
Boolean success = false;
ProsName = "AppendStringToFile";
Data = "";
lock (this)
try
filePath = rootdirectory + "\\" + fname;
// The using statement ensures that Dispose is called on fileHandle even if an exception occurs.
filehandle = new FileStream(filePath, FileMode.Append);
stringToWrite = stringToWrite + "\r\n";
byte[] databt = Encoding.UTF8.GetBytes(stringToWrite);
filehandle.Write(databt, 0, databt.Length);
filehandle.Close();
catch (Exception ex)
Fnlstr = DateTime.Now.ToString() + "," + "Class Name:-" + ClsName + "," + "Procedure Name:-" + ProsName + "," + "Data:-" + Data + "," + "Error Msg:-" + ex.Message;
Glbsd.SDAppendStringToFile(Fnlstr, "ErrorLog.csv");
Debug.Print(ex.Message);
return success;
Sorry for the long messge but i think its require to know the problem and to provide solution.
Do you know the line in your code where it hangs?
How big is the string you write to the file?
Do you start with empty file and then after 9 hours it happens or is there a file already that you are appending to.
9 hours * 1 string a minute = 540 strings written before it hangs. Is that correct?
Ans:- I don’t know the line but when i have comment calling “AppendStringToFile” function. it works properly. I have tried with error handling too but no error file generates in SD card.
I think somebody had similar issue before. Search the forum.
As a workaround you can split logging into smaller files 200 entries per file or so for example.
Monitor the debug output. Do you get any exceptions at all?
also, make sure your program is still working. I mean if some thread exits, it seems that it is hanging
The status information you are seeing below is fine, this is just the output that the Garbage Collector produces as it operates.
You said that the other threads have hung - how do you know? And you say the UI is still operating, does that mean you can still interact with the device?
At the ~14 hour mark, what actually happens? Can you issue a break in VS and see where the code is up to? Can you add debug.print statements at strategic points in the code to see what is going on immediately before ?
Thanx Gus, you are right that you got the problem.
Actually GC was removing my object which I have declared static and define in program.cs. The object is responsible for running 1 minute timer thread written in class and as the object dispose/removed by GC the whole timer thread stops and the SD storage stops.
I have checked with initializing local object in a class and defining 1 minute timer thread in same class and it works properly.
But, I want to define the 1 minute thread globally so, irrespective of any classs dependency it should acquire sensor data and store sensor data in SD card. I have tried with defining the class object in program.cs but GC is removing it though the timer is executing every 1 minute.
Please guide me how to achieve this. I may have wrong idea but can be stop GC to execute? This may help but I dont know it may occur other problems of not.
