To communicate with PC using USB ClientDP module do I need to write a CDC (because I am using FEZ SPIDER and in here [quote]Key Features:
14 .NET Gadgeteer compatible sockets that include these types: X, Y, A, C, D, E, F, H, I, K, O, P, S, T, U, R, G, B and Z.
Configurable on-board LED
Configuration switches
Based on GHI Electronics EMX module
72MHz. 32-bit ARM7 processor
4.5 MB Flash
16 MB RAM
LCD controller
Full TCP/IP Stack with SSL, HTTP, TCP, UDP, DHCP
Ethernet, WiFi driver and PPP ( GPRS/ 3G modems) and DPWS
USB host
USB Device with specialized libraries to emulate devices like thumb-drive, [italic][b]virtual COM (CDC),[/b][/italic] mouse, keyboard
76 GPIO Pin
2 SPI (8/16bit)
I2C
4 UART
2 CAN Channels
7 10-bit Analog Inputs.
10-bit Analog Output (capable of WAV audio playback)
4-bit SD/MMC Memory card interface
6 PWM
OneWire interface (available on any IO).
Built-in Real Time Clock (RTC) with the suitable crystal
Processor register access
OutputCompare for generating waveforms with high accuracy
RLP allowing users to load native code (C/Assembly) for real-time requirements.
Extended double-precision math class
FAT File System
Cryptography (AES and XTEA)
Low power and hibernate support
In-field update (from SD, network or other)
Dimensions: W 2.25" x L 2.05" x H 0.5"
Power
Requires .NET Gadgeteer standard red modules to power the system like USB client DP.
Low power and hibernate modes
Active power consumption 160 mA
Idle power consumption 120 mA
Hibernate power consumption 40 mA
Environmental:
Operating temperature: -20 to 70°C
RoHS compliant /Lead-free compliant
For more information about .NET Gadgeteer visit:
http://www.netmf.com/gadgeteer/[/quote] they mention bout that Spider have CDC)? or can I do this in other way to communicate with PC using USB ClientDP module?
