First of all, thanks in advance for your help !
I’m using a STM32F4Discovery board with the Cerberus firmware, and everything works fine, except for one timer i’m using to count pulses. I’ve tested the counter with TIM3 successfully, but when i use TIM12, the whole board “speeds up”.
You probably would be asking why not to use another timer instead, well, the answer is that i have already a few custom boards where this signal is mapped to TIM12 (i’ve never expected this wierd behavior)
I have a few threads with “sleeps”, and if i don’t apply pulses to the external input the delays are ok, but as soon as signal is detected the “sleep’s” stop waiting the correct amount of time.
The blinking led goes faster, also the date & time of the board goes faster, so i’m quite sure that this timer is used by the framework. I not sure if the cerb source code is available to check if that timer is in use, i couldn’t find it.
According to the ST reference manual, this timer is fully independent,
The most confusing part is that only happens when signal is connected, and not after the timer inicialization. If this pin is tied to GND the board still works fine. And the same code for TIM3 works just fine.
This is the code i’m using…
static private void thread_T12_PULSECOUNTER()
uint CCR1 = 0; uint CCR2;
const UInt32 PERIPH_BASE = 0x40000000;
const UInt32 APB1PERIPH_BASE = PERIPH_BASE;
const UInt32 AHB1PERIPH_BASE = PERIPH_BASE + 0x00020000;
const UInt32 TIM12_BASE = APB1PERIPH_BASE + 0x1800;
const UInt32 RCC_BASE = AHB1PERIPH_BASE + 0x3800;
const UInt32 GPIOB_BASE = AHB1PERIPH_BASE + 0x0400;
Register RCC_APB1ENR = new Register(RCC_BASE + 0x40);
Register RCC_AHB1ENR = new Register(RCC_BASE + 0x30);
Register GPIOB_MODER = new Register(GPIOB_BASE + 0x00);
Register GPIOB_AFRH = new Register(GPIOB_BASE + 0x24);
Register TIM12_CR1 = new Register(TIM12_BASE + 0x00); //TIM control register 1
Register TIM12_SMCR = new Register(TIM12_BASE + 0x08); //TIM slave mode control register
Register TIM12_CCMR1 = new Register(TIM12_BASE + 0x18); //TIM capture/compare mode register 1
Register TIM12_CCER = new Register(TIM12_BASE + 0x20); //TIM capture/compare enable register
Register TIM12_CNT = new Register(TIM12_BASE + 0x24); //TIM Counter
Register TIM12_CCR1 = new Register(TIM12_BASE + 0x34); //TIM capture/compare register 1
Register TIM12_CCR2 = new Register(TIM12_BASE + 0x38); //TIM capture/compare register 2
RCC_APB1ENR.SetBits(0x40); //TIM12 clock enabled (BIT 6)
RCC_AHB1ENR.SetBits(0x02); //GPIOB enabled
GPIOB_MODER.ClearBits(0xC0000000);
GPIOB_MODER.SetBits(0x80000000); //PB15 as Alternate function mode
GPIOB_AFRH.ClearBits(0xF0000000);
GPIOB_AFRH.SetBits(0x90000000); //PB15 Alternative function 9
TIM12_CCMR1.Value = 0x02; //CC1 channel as input, IC1 is mapped on TI2
TIM12_SMCR.Value = 0x67; //SMS=111 External Clock Mode 1 - Rising edges of the selected trigger (TRGI) clock the counter
//TS=110 Filtered Timer Input 2 (TI2FP2)
TIM12_CCER.Value = 0x03; //CC2E=1 / CC1E=1 BOTH CAPTURE FALLIN' EDGE
TIM12_CCR1.Value = 0; //Clear CCR
TIM12_CCR2.Value = 0; //Clear CCR
TIM12_CNT.Value = 0; //Clear Counter
TIM12_CR1.Value=0x01; //Counter enabled
pulseCounter = 0;
Thread.Sleep(1000);
CCR1 = TIM12_CCR1.Value;
CCR2 = TIM12_CCR2.Value;
