Hi
I have an older development board. An Embedded Master Dev. Sys. Rev 2.4A with an LCD display.
It currently runs TinyCLR 4.0, and I am trying to update it to 4.1.
I have installed the USB drivers, GHI SDK, Thera Term and the NETMF 4.1 from here:
http://www.ghielectronics.com/catalog/product/107
Everything installed nicely.
I then looked at the video here: - YouTube - I believe it should be the same for EM.
I connect the USB interface to the USB port on the lower right on the board (power connector is on right side top).
When starting the device I hold UP, Select and Down button, and the board boots to a white screen; instead of the normal black TinyCLR screen with text.
Windows detects it as a virtual COM port 4.
So far so good.
I then start and connect TeraTerm to COM4.
When pressing V or q - nothing happens. According to the video it should respond with the version, or BL.
When pressing key in TeraTherm the TX LED near the USB interface blinks.
Any advice on resolving the issue?
I tried both on a Windows 7 64bit and a Windows XP 32 bit - same result.
If I connect the USB cable to the left top USB connector, MFDeply recognize it as EMX_EMX.
Pinging... TinyCLR
HalSystemInfo.halVersion: 4.0.1681.0
HalSystemInfo.halVendorInfo: Microsoft Copyright (C) Microsoft Corporation. All rig
HalSystemInfo.oemCode: 255
HalSystemInfo.modelCode: 0
HalSystemInfo.skuCode: 65535
HalSystemInfo.moduleSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
HalSystemInfo.systemSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
ClrInfo.clrVersion: 4.0.1681.0
ClrInfo.clrVendorInfo: Microsoft Copyright (C) Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion: 4.0.1681.0
SolutionReleaseInfo.solutionVersion: 4.0.3.0
SolutionReleaseInfo.solutionVendorInfo: GHI Electronics, LLC
SoftwareVersion.BuildDate: May 21 2010
SoftwareVersion.CompilerVersion: 310739
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 480
LCD.Height: 272
LCD.BitsPerPixel: 16
AppDomains: True
ExceptionFilters: True
IncrementalDeployment: True
SoftReboot: True
Profiling: False
ProfilingAllocations: False
ProfilingCalls: False
IsUnknown: False
- any advice is appreciated
