I am having problem to update my raptor to tinyCLR version 4.3.6.0
I used the SAM-BA v2.12 with the update.bat files. the tinybooter update worked has expected.
Then I use Fez config to update the tinyCLR with the firmware updater the process is successful. But my raptor is still with no tinyclr in it. I also use the advanced REBOOT CLR but it doesn’t work. There are still no tinyCLR
G400 SoC products: Ground PA11, reset or power cycle the board. With power still ON, unground PA11
FEZ Raptor mainboard:
connect the board to the power supply and computer,
locate socket 3,
on socket 3, connect pins 8 and 10 with a wire,
press the reset button on the Raptor board,
remove the wire ("unjumper") from pins 8 and 10
In either case, be sure to unjumper the FEZ Raptor board or the G400 processor within 3 seconds.
I’ve experienced the same problem with two Hydra boards. They have been updated but FEZ Config shows this message each time. Try deploying a simple project, I used a new empty one, and check that it deploys correctly.
