using System.IO.Ports;
using System.Text;
using Microsoft.SPOT.IO;
using GHIElectronics.NETMF.USBHost;
using System.IO;
SerialPort UART = new SerialPort("COM1");
UART.BaudRate = 115200;
UART.Parity = Parity.None;
UART.StopBits = StopBits.One;
UART.DataBits = 8;
UART.Handshake = Handshake.None;
UART.Open();
UART.DataReceived += new SerialDataReceivedEventHandler(DataReceived);
UART.ErrorReceived += new SerialErrorReceivedEventHandler(UART_ErrorReceived);
private static void DataReceived(object sender, SerialDataReceivedEventArgs e)
Debug.Print("trigger");
System.Text.Encoding enc = System.Text.Encoding.UTF8;
SerialPort UART = new SerialPort("COM1", 115200);
byte[] chbyte = new byte[1];
UART.Read(chbyte, 0, 1);
string myString = new string(enc.GetChars(chbyte));
Debug.Print(myString);
if (string.Compare(myString, "p") == 0)
Debug.Print("ping");
System.Text.Encoding enc1 = System.Text.Encoding.UTF8;
byte[] ping = new byte[1];
ping = enc1.GetBytes("p");
UART.Write(ping, 0, 1);
private static void UART_ErrorReceived(object sender, SerialErrorReceivedEventArgs e)
Debug.Print("error");
Above is the isolated code for “pinging” the Fez Domino.
The Fez will receive “p” via UART and responds with “p” also.
Computer: p
C# debug output: trigger
Fez: p
Computer: p
C# debug output:(none)
Fez: (no response)
Is there something wrong with the code?
