I connected a DS18B20 to my cerberus board (4K7 pull-up on one wire data line for parasite mode).
I read the device using pin PA1.
The search function find the device but I always read 85 deg C (reset default value).
Can anyone help me with this issue?
Output of the program:
286F5A24000000AF: 85.0 deg C
The source of the program is the following:
using System.Collections;
namespace DS18B20_Demo
OutputPort output = new OutputPort((Cpu.Pin) 1, false);
OneWire ow = new OneWire(output);
byte[] address = new byte[8];
ArrayList devs = ow.FindAllDevices();
if (devs.Count > 0)
// Extract serial of the first device on the bus
Array.Copy((byte[])devs[0], address, 8);
if (address[0] == 0x28)
// It's a DS18B20
float temperature = ReadTemperature(ow, address);
// !!!!! Always read 85 deg C.
Debug.Print(address[0].ToString("X2") + address[1].ToString("X2") + address[2].ToString("X2") + address[3].ToString("X2") + address[4].ToString("X2") + address[5].ToString("X2") + address[6].ToString("X2") + address[7].ToString("X2") + ": " + temperature.ToString("F1") + " deg C");
Thread.Sleep(1000);
private static class DS18B20Command
public const byte SearchROM = 0xF0;
public const byte ReadROM = 0x33;
public const byte MatchROM = 0x55;
public const byte SkipROM = 0xCC;
public const byte AlarmSearch = 0xEC;
public const byte StartTemperatureConversion = 0x44;
public const byte ReadScratchPad = 0xBE;
public const byte WriteScratchPad = 0x4E;
public const byte CopySratchPad = 0x48;
public const byte RecallEEPROM = 0xB8;
public const byte ReadPowerSupply = 0xB4;
private static void WriteBytes(OneWire ow, byte[] data)
for (var i = 0; i < data.Length; i++)
ow.WriteByte(data[i]);
public static float ReadTemperature(OneWire ow, byte[] address)
var data = 0L;
// if reset finds no devices, just return 0
if (ow.TouchReset() == 0)
return 0;
// address the device
ow.WriteByte(DS18B20Command.SkipROM);
//WriteBytes(ow, address);
// tell the device to start temp conversion
ow.WriteByte(DS18B20Command.StartTemperatureConversion);
// wait for as long as it takes to do the temp conversion,
// data sheet says ~750ms
while (ow.ReadByte() == 0)
System.Threading.Thread.Sleep(1);
// reset the bus
ow.TouchReset();
// read the data from the sensor
ow.WriteByte(DS18B20Command.ReadScratchPad);
// read the two bytes of data
data = ow.ReadByte(); // LSB
data |= (ushort)(ow.ReadByte() << 8); // MSB
// reset the bus, we don't want more data than that
ow.TouchReset();
// returns C
// F would be: (float)((1.80 * (data / 16.00)) + 32.00);
return (float)data / 16f;
