i try to write file-segments using filestream onto usb-media.
the segments are written by .write and .flush operation.
inspite of this the whole write operation is blocked after some flush operations. after this block-time (30s upwards) the
code continues in program with the rest of file segment write operations.
the file-stream operations are capsulated in .net microfm libs.
which buffer options can be additionally set on g400?
(basically i know about the direct call of microsoft.spot.io.volumeinfo("…).flushall)
