I’m having trouble installing the bootloader driver for my FEZDomino board. The board itself has firmware version 4.0.2.0 installed and I’m trying to upgrade to .NETMF 4.1 and firmware 4.1.1.0 in the hope it will solve the problems I’m experiencing with SPI.
The NET MF interface driver installs with no problem. When I try to install the bootloader interface it fails with the message:
‘A service installation section in the INF is invalid’
You are probably using the wrong driver.
Follow steps in downloads, user guides…etc to :
Uninstall any existing version and SDKs you have.
Install visual studio 2010, NETMF 4.1, our latest SDK.
There are automated driver installer in downloads.
When I uninstall I go to Device Manager and under Ports there’s a USBizi entry with a yellow exclamation mark. I right click it and select ‘Uninstall’.
It complained about an invalid service section in the INF file. I concluded from looking at the INF that it had to be the usbser.sys not being present, and that turned out to be the case.
Well, since that is a system file I’m really surprised that it was not on your machine already. What OS are you using? I see there is a 4 year old hotfix out for XP for a similar issue but would suspect if your running with the latest service pack (3) you should not have had this issue.
