I have a problem with the installer of .NET Microframework SDK 4.2. I work with OS Win7, Visual Studio 2010 and I have downloaded the programs for to work with Netduino plus 2 from official website. I am doing test of exception error on the code and when I run the code line of the socket the program stops and exits the compiler. Obviously I want to treat socket error when network cable is disconnected but I get the error mentioned above.
Deputy of the code to treat socket exception error.
The problem is in the Micro Framework SDK 4.2 under W7 as are those who manage libraries Netduino functions. When working in Windows XP there is no problem in working errors that may occur in the Netduino but changing to Windows 7 is when you have the problem above. It is desirable that could fix this in order to continue working with working under Windows platforms.Thanks for your answer.
when is a program where not is working Sockets with then the debugger works. The problem is when running the line of sockets and not connected the network cable. In XP the program sets the Socket exception error but when is running with W7 not shows nothing error and closes on VS 2010. I’ve also tested with VS 2012 and gives the same problem.
I think the problem is in the installation of the Micro Framework on W7 of 64 bits because libraries are not containing the. NET. If por example, I want testing that the network cable is connected in each time, it not is posible. I have tested in multiple computers on W7 and it not works. I’ve tried with the programs downloaded directly from the website of Netduino and from the website Micro Framework with the version required, and in any way does not work.
