I have a GHI Spider. I am using VC# 2012 Express. I connected a button, display T35, and a GHI SD Card version 1.4.
I have used all but the SD Card OK.
I tried to follow the SD Card example NETMF API-> NETMF IO -> PersistentStorage.
When I try to debug the code, I get
Using mainboard GHIElectronics-FEZSpider version 1.0
#### Exception System.InvalidOperationException - CLR_E_INVALID_OPERATION (1) ####
#### Message:
#### GHIElectronics.NETMF.IO.PersistentStorage::.ctor [IP: 0000] ####
#### SDCard.Program::ProgramStarted [IP: 002f] ####
#### SDCard.Program::Main [IP: 0015] ####
A first chance exception of type 'System.InvalidOperationException' occurred in GHIElectronics.NETMF.IO.dll
An unhandled exception of type 'System.InvalidOperationException' occurred in GHIElectronics.NETMF.IO.dll
<\code]
The exception happens when attempting
ps = new PersistentStorage("SD");
which I put in the ProgramStarted() function.
Do you also have VC# 2010 by any chance? I’d suggest trying that, because I think officially the netmf SDK is not yet supported in VS11.
Having said that, an error like that usually means the SDK and firmware versions don’t match - do they? Can you repro this on a new project that only adds the SD card?
I AM using VC# 2010 ;D In gadgeteer, I added spider, USB DP, display t35,
SDCard. Then used auto connect.
Program.cs
using System.IO;
using System.Collections;
using Microsoft.SPOT.Touch;
using Microsoft.SPOT.IO;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace SDCard
public partial class Program
// Hold a static reverence in case GC kicks in...
static PersistentStorage ps;
timer.Tick +=<tab><tab>
timer.Start();
button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
RemovableMedia.Insert += new InsertEventHandler(RemovableMedia_Insert);
RemovableMedia.Eject += new EjectEventHandler(RemovableMedia_Eject);
// Assume SD card is inserted
// Create a new storage device
if (PersistentStorage.DetectSDCard())
Debug.Print("SD Card detected");
ps.MountFileSystem();
// Sleep forever
void RemovableMedia_Insert(object sender, MediaEventArgs e)
Debug.Print("Storage \"" + e.Volume.RootDirectory + "\" is inserted.");
Debug.Print("Getting files and folders:");
if (e.Volume.IsFormatted)
string[] files = Directory.GetFiles(e.Volume.RootDirectory);
string[] folders = Directory.GetDirectories(e.Volume.RootDirectory);
Debug.Print("Files available on " + e.Volume.RootDirectory + ":");
for (int i = 0; i < files.Length; i++)
Debug.Print(files[i]);
Debug.Print("Folders available on " + e.Volume.RootDirectory + ":");
for (int i = 0; i < folders.Length; i++)
Debug.Print(folders[i]);
Debug.Print("Storage is not formatted. Format on PC with FAT32/FAT16 first.");
// We do not need it any more
ps.Dispose();
void RemovableMedia_Eject(object sender, MediaEventArgs e)
Debug.Print("Storage \"" + e.Volume.RootDirectory + "\" is ejected.");
void button_ButtonPressed(Button sender, Button.ButtonState state)
Debug.Print("Button Pressed");
button.ToggleLED();
Mike,
Sorry about the 2012 typo in original post.
I upgraded firmware. Same exception.
I created a new project.
Changed the main board to spider
added an SD card
added USB DP
Auto connect
Added resources to eliminate errors, GHIElectronics.NETMF.[IO,System], System.IO.
Both with and without an SD card inserted, I get the same exception.
as Mike said you are mixing gadgeteer and non gadgeteer code:
also never ever use this in gadgeteer…
// Sleep forever
in Gadgeteer all you would need is:
timer.Start();
sdCard.SDCardMounted += new SDCard.SDCardMountedEventHandler(sdCard_SDCardMounted);
sdCard.SDCardUnmounted += new SDCard.SDCardUnmountedEventHandler(sdCard_SDCardUnmounted);
void sdCard_SDCardUnmounted(SDCard sender)
Debug.Print("unmounted");
void sdCard_SDCardMounted(SDCard sender, GT.StorageDevice SDCard)
Debug.Print("SD Mounted");
var root = sdcard.ListRootDirectoryFiles();
foreach (var fileName in root)
Debug.Print(" " + fileName);
also you may want to do a search in the forum for more info.
Enjoy!.
