Hi!
I am using a ChipworkX, and a EMX devboard together with two modems: the Airlink GL 6110 and the Siemens MC35i.
In any combination (devboard and modem) establishing a PPP connection works fine.
Therefore I am using a slightly modified version of your PPP class demo code from the SDK manual (ATcommander, etc.)
Here are the AT commands which I printed out in the output window:
[quote]Dial-in using AT commands
AT
OK
AT+CGMI
SIEMENS
OK
AT+CGMM
MC35i
OK
AT^SCKS=?
^SCKS: (0,1)
OK
ATV1
OK
ATH
OK
ATZ
OK
ATE
OK
The thread ‘’ (0x15cc) has exited with code 0 (0x0).
AT\Q1
OK
AT+CSQ
+CSQ: 27,99
OK
AT+CGREG=1
OK
AT+CGATT=1
OK
AT+CGATT?
+CGATT: 1
OK
AT+CGREG?
+CGREG: 1,1
OK
AT
OK
AT+CGDCONT=1,“IP”,“web.one.at”
OK
ATD99**1#
CONNECT
AT connected, Ready for PPP connection Establishing!
Connect PPP
PPP connection was established!
PPP Network settings:
IP Address: 10.102.121.197
Subnet Mask: 255.255.255.0
Default Getway: 192.168.254.254
DNS Server: 81.3.216.100[/quote]
As you can see, I have an IP address. Now I tried to send the IP address as a string from the devboard to a console application which runs on my laptop, so that the laptop can answer with a “hello world” or something like that.
Using sockets, the server receives that message - it works like a charm. However sending back a “hello world” does not work, though I have a socket bound to “0.0.0.0” port 80 on the devboard. (I thought using 80 would be best to walkaround any firewall issues ;-))
Additionally, I cannot ping my device from my laptop using the aforementioned IP address.
When I do a tracert in command line, my router does not know where to route that IP address to:
[quote]C:\Users\Alex>tracert 10.100.58.169
Routenverfolgung zu 10.100.58.169 über maximal 30 Abschnitte
1 <1 ms <1 ms <1 ms 192.168.0.1
2 * * * Zeitüberschreitung der Anforderung.
3 * * * Zeitüberschreitung der Anforderung.
4 * * * Zeitüberschreitung der Anforderung.
5 * * * Zeitüberschreitung der Anforderung.
6 * * * Zeitüberschreitung der Anforderung.
7 * * * Zeitüberschreitung der Anforderung.
8 * * * Zeitüberschreitung der Anforderung.
9 * * * Zeitüberschreitung der Anforderung.
10 * * * Zeitüberschreitung der Anforderung.
11 * * * Zeitüberschreitung der Anforderung.
12 * * * Zeitüberschreitung der Anforderung.
13 * * * Zeitüberschreitung der Anforderung.
14 * * * Zeitüberschreitung der Anforderung.
15 * * * Zeitüberschreitung der Anforderung.
16 * * * Zeitüberschreitung der Anforderung.
17 * * * Zeitüberschreitung der Anforderung.
18 * * * Zeitüberschreitung der Anforderung.
19 * * * Zeitüberschreitung der Anforderung.
20 * * * Zeitüberschreitung der Anforderung.
21 * * * Zeitüberschreitung der Anforderung.
22 * * * Zeitüberschreitung der Anforderung.
23 * * * Zeitüberschreitung der Anforderung.
24 * * * Zeitüberschreitung der Anforderung.
25 * * * Zeitüberschreitung der Anforderung.
26 * * * Zeitüberschreitung der Anforderung.
27 * * * Zeitüberschreitung der Anforderung.
28 * * * Zeitüberschreitung der Anforderung.
29 * * * Zeitüberschreitung der Anforderung.
30 * * * Zeitüberschreitung der Anforderung.
Ablaufverfolgung beendet.[/quote]
Can you see what I am doing wrong? It seems as if the device tells me to have an IP address that does not exist…
Please help! I do not know what do try next anymore…
