Power.GetResetSource() doesn't give me the expected answer
Hello,
On my FEZ Pico, I am (successfully) using the Shutdown function like this:
        Power.WakeupEdge = WakeupEdge.Rising;
        Power.Shutdown(true, DateTime.Now.AddSeconds(10));
Is there any way to know if the board is restarted by the WKUP input or by the clock?
I tried the following, but that returns ‘ResetSource.Other’ in both cases:
        ResetSource resetSource = Power.GetResetSource();
Hi, will will look in next release. For now, you can check this link:
Check my last post, something like this:
     const uint PWR_SR1 = 0x40000000U + 0x7000U + 0x10;
     const uint PWR_SCR = 0x40000000U + 0x7000U + 0x18;
     // Read wakeup source -> Read must be done before clear or it will be set to 0.
     var wakeupSource  = Marshal.ReadInt32((IntPtr)PWR_SR1, 0);
     if ((wakeupSource & (1 << 0)) != 0)
         Debug.WriteLine("Wk by PA0");
     else if ((wakeupSource & (1 << 3)) != 0)
         Debug.WriteLine("Wk by PA2");
    else {
         Debug.WriteLine("Wk by rtc timer");
    // Enter Shutdown
Thanks!
I’m going to try it :slight_smile:
