Say I wanted to power several lower power usage boards, could I use the Power Extender Module?
Or if wanted 2 boards running 2 power hungry modules, could I use this module?
That is exactly what that module is for. You will need one per board.
I didn’t clarify myself …
If I wanted 4 Cerberus boards, could I use 1 Extender to run all of them?
Or
If I wanted 2 Cerberus boards, each with a power hungry module, could I use 1 Extender to run both set of them?
I think it should be possible don’t see why not.
Bear in mind it wont supply any more juice than a red module…
