I wanted to find out if postmanagedevent is received in the same order it is sent and it would appear it is. But there appears to be a max of 15 events that can be posted? I have the below code in RLP/.NET and I only ever receive 15 events.
int i;
for(i = 0; i<100000; i++)
RLPext->PostManagedEvent(i);
This queues a managed event to be sent to RLPEvent (not sent immediately).
It is a queue of size 16. when you read in C#, you can send more events from native code.
It is not intended to send many events every milli-second. This will slow everything down a lot.
No. Usually they are read in CLR code ASAP. This is the same as regular InterruptPort events.
You can implement your own event queue and read them from C# periodically…
Good to know that! And how many events from InterruptPort can be stored at the same time? The number divided by minimum time needed to be spend in manage code event handler determins the freq of signal that can be decoded without PinCapture class (so core net mf)…
The manged event handler does not matter. It is a bit more complex.
From native code you can send several events up to a limit.
Then they are transferred to CLR as soon as it gets a chance to. There is no limit here.
This is done very well in NETMF. You will hardly miss any events.
