Is it possible to pilot 2 instances of the FLASH Gadgeteer module on the same SPI Bus ?
As the Flash can not comply multiplt R/W on the same sectors, and to avoid using MicroSD just for couple MB of datas, I was imagining to have 2 flash :
One for configuration files that will be stored inline,
One for frequently changing datas that will use the FS, and then as it is each time a complete replacment, I will erase the FLASH before writing these datas…
If your device has USB host support, then I would consider using a thumb drive instead of two flash modules. Not sure what the advantages of flash module, except perhaps less power.
The idea is also to have something “discret”, so that and USB stick is not convinient. If you thnik it is poor of performance with FLASH, than I keep my first idea of a microSD Card. It is cheap, discret, and can stay lifetime in the box…
I was not saying anything bad about flash technology.
From my view, the flash module costs about $15 and you get 4MB of memory.
For $5 you can get a USB Host module, and then you have a choice of
memory sizes in the GBs starting around $5.
There is also GHI support for USB Host mass storage versus a community supported file
system for the flash module.
BTW, USB drives come in many shapes. Here is a picture of the usb drive I use in my timesharing system. It is very small and discret. It is in lower right corner of board.
