This is my first post and I’d like to say thank you to everyone at GHI for developing such great products.
I’m working with a third-party .NET 32-bit .dll used to drive a motor through a USB interface. I’ve successfully compiled and run a .NET Framework 2.0 Windows Application using the third-party .dll to control the motor using my PC.
However, I’m now trying to port the .dll over to my FEZ Spider board and hope to drive the motor through the USB Host module. Just adding the .dll into my .NET MF Framekwork 4.1 gives me an error of .pe file in a path relative to the .dll path. I do not have a .NET MF proprietary .pe file, only the .NET Framework 2.0 .dll. I have asked the supplier to see if they could port their code over to be .NETMF compatible, but I’m not holding out any hopes.
I’ve attempted to use the MetaDataProcessor.exe command line tool provided with the .NET MF Porting Kit 4.1 and 4.2 to convert the .dll to the .NET MF proprietary .pe format.
MetaDataProcessor.exe -loadHints mscorlib mscorlib.dll -parse <dll File Name>.dll -minimize -compile <pe File Name>.pe
But I get the following error:
error MMP0000: Cannot resolve type System.Runtime.CompilerServices.CompilerGeneratedAttribute from assembly <dll File Name>!
MMP: error MMP0000: CLR_E_FAIL
My current plan of action is to:
[ul]See if I can obtain the supplier’s source code used to make the .dll so I can port the code to .NET MF by replacing multidimensional arrays to be replaced with jagged arrays. Is there any documentation comprehensively detailing what else needs to be changed during a port from .NET to .NET MF? Nonetheless, I’m not too optimistic I can get my hands on the source.[/ul]
[ul]Try another communication protocol such as CANOpen instead of USB.[/ul]
I’ve scoured the internet and can’t seem to find a solution to this problem. Sorry if there’s an obvious answer to this.
Thank you so much for your help. Any comments or even suggestions on where I should look are appreciated.
