How can I find the mentioned addresses in the bug for that MCU so I may apply the patch?
Basically, I’m pulsing a pin at 500ms sleep intervals. When debugging its perfect at 500ms, however, when not debugging it goes up to 600ms (via scope).
look at your out put map file, take a look on:
TinyCLR_UsbClient_SetDataReceivedEvent is MODE_ADDRESS
SystemEvents is EVENT_ADDRESS
offset is 0 if these addresses < int.MaxValue.
or offset = address - int.MaxValue.
