Points and rewards
Should there be a difference between exp points and reward points?
What do you mean?
@ HughB - experience points always go up, rewards will go up and down after each spend at the GHI candy store
Are reward points based on the number of xp. For example 100 xp = 100 reward points?
The reason I ask is I was browsing around and found the reward page which lists my points but it’s a different number to my xp points
yes it will be different since experience started since you became a member but rewards started at a later time when we added this feature.
Ok cool, I thought it must be something like that :slight_smile: many thanks Gus.
