Mark,
I got stuck with the snippet of code for printing out the current reading (I modified the class name for my current sensor model, but all of your code stays the same):
using (ICurrentSensor sensor = new ACS758KCB_150B((Cpu.Pin)AnalogIn.Pin.Ain15, (CurrentSensorBase.SensorMode)CurrentSensorBase.SensorMode.MostAccurate))
Debug.Print("Amps: " + sensor.GetCurrent() + "A");
Thread.Sleep(1000);
The VS2010 gives me an error:
“Sensors.ICCurrent.CurrentSensorBase” does not implement the member of interface “Sensors.ICCurrent.ICurrentSensor.GetCurrentInAmps()”
Here is the full code the way I put in all the cutouts you shared in three separate pages at code.tinyclr.com:
public static void CurrentSensor_Thread()
currentNow = sensor.GetCurrent();
Thread.Sleep(1000);
// Ascended International
// Copyright (c) 2010
// All Rights Reserved
// * DO NOT REMOVE THIS HEADER. DO NOT MODIFY THIS HEADER *
* You may use this class for non-commerical purposes. If you wish to use this *
* software for a commercial pupose please contact Ascended International at: *
* mark@ ascended.com.au *
* When using this free class, no warranty express or implied is offered. *
* In no event shall Ascended International, any of it's employees or shareholds *
* be held liable for any direct, indirect, special, exemplary, incidental or *
* consequential damages however caused. *
* If you modify this class, please add your name and the date below as a *
* contributor, without removing this notice or modifying it in any way, shape *
* or form. *
namespace Sensors.ICCurrent
public class ACS758KCB_150B : CurrentSensorBase
/// <summary>
/// Create a new base instance of the current sensor.
/// </summary>
/// <param name="pin">Pin the sensor's vout is connected to.</param>
public ACS758KCB_150B(Cpu.Pin pin)
: base(pin)
MaximumCurrentCapability = 150;
MinimumCurrentCapability = -150;
public ACS758KCB_150B(Cpu.Pin pin, SensorMode mode)
: base(pin, mode)
protected override double ReadSensorValue()
double x = sensor.Read() - 2527;
return x / 185;
public interface ICurrentSensor : IDisposable
double GetCurrentInAmps();
bool UseMovingAverage { get; set; }
int MovingAverageSize { get; set; }
bool UseAveraging { get; set; }
int AverageSampleCount { get; set; }
bool UseFiltering { get; set; }
float MaximumCurrentCapability { get; }
float MinimumCurrentCapability { get; }
CurrentSensorBase.SensorMode SensorReadMode { get; set; }
public abstract class CurrentSensorBase : ICurrentSensor
protected AnalogIn sensor;
protected double[] movingValues;
int movingPos;
double[] data;
double[] values;
/// <summary>
/// This should not be used as there is no way to set the pin your sensor is on. This is here for inheritance.
/// </summary>
public CurrentSensorBase()
/// <summary>
/// </summary>
public CurrentSensorBase(Cpu.Pin pin)
Initialize(pin);
SetDefaults();
/// <summary>
/// Settings for running the sensor
/// </summary>
public enum SensorMode
/// <summary>
/// Define your own settings using the properties on the class
/// </summary>
Custom,
/// <summary>
/// Read the sensor value out as fast as possible. No filtering or averaging will be done.
/// </summary>
FastestRead,
/// <summary>
/// Read the sensor as accurately as possible. All filtering and averaging will be done - if required.
/// </summary>
MostAccurate,
/// <summary>
/// The the accurately, but also try to do it quickly. This is best for most uses.
/// </summary>
BestTradeoff
public CurrentSensorBase(Cpu.Pin pin, SensorMode mode)
Initialize(pin);
SensorReadMode = mode;
if (mode == SensorMode.Custom)
SetDefaults();
internal void SetDefaults()
UseMovingAverage = false;
MovingAverageSize = 5;
UseAveraging = true;
AverageSampleCount = 10;
movingValues = new double[MovingAverageSize];
FillMovingAverageValues();
internal void Initialize(Cpu.Pin pin)
sensor = new AnalogIn((AnalogIn.Pin)pin);
sensor.SetLinearScale(0, 3300);
/// <summary>
/// Returns the current in amps and will apply any filtering or averaging before returning the value.
/// </summary>
/// <returns>The current the sensor is reading in Amps.</returns>
public double GetCurrent()
double amps = 0;
if (UseAveraging)
data = new double[AverageSampleCount];
double min = Double.MaxValue;
double max = Double.MinValue;
for (int i = 0; i < AverageSampleCount; i++)
double val = ReadSensorValue();
data[i] = val;
amps += val;
if (UseFiltering)
if (min > val)
min = val;
if (max < val)
max = val;
amps = amps / AverageSampleCount; // faster than /=
if (UseFiltering)
// do we need to do cleanup through deviation?
if (!(max == min || max - min < 1))
// trim down the data
double stdDev = StandardDeviation(data, amps);
// Standard Dev is too high for our liking!
if (stdDev > 0.5)
int candidates = 0;
values = new double[AverageSampleCount];
double dat = data[i];
if (dat < amps + stdDev && dat > amps - stdDev)
values[candidates++] = dat;
amps = Average(values, candidates - 1);
amps = ReadSensorValue();
if (UseMovingAverage)
AddMovingAverage(amps);
return Average(movingValues);
return amps;
protected abstract double ReadSensorValue();
static double StandardDeviation(double[] data, double avg)
//double avg = 0;
double totalVariance = 0;
int max = data.Length;
if (max == 0)
return 0;
// get variance
for (int i = 0; i < max; i++)
double variance = data[i] - avg;
totalVariance = totalVariance + (variance * variance);
return MathEx.Sqrt(totalVariance / max);
static double Average(double[] data)
return Average(data, data.Length);
static double Average(double[] data, int count)
double avg = 0;
for (int i = 0; i < count; i++)
avg += data[i];
if (avg == 0 || count == 0)
return 0;
return avg / count;
void AddMovingAverage(double nextValue)
movingValues[movingPos++] = nextValue;
if (movingPos >= movingValues.Length)
movingPos = 0;
protected void FillMovingAverageValues()
for (int i = 0; i < movingAverageSize; i++)
AddMovingAverage(ReadSensorValue());
private SensorMode sensorReadMode;
public SensorMode SensorReadMode
get { return sensorReadMode; }
set
if (sensorReadMode == value)
return;
sensorReadMode = value;
switch (value)
case SensorMode.FastestRead:
UseAveraging = false;
UseFiltering = false;
break;
case SensorMode.MostAccurate:
UseFiltering = true;
UseMovingAverage = true;
break;
case SensorMode.BestTradeoff:
AverageSampleCount = 5;
break;
case SensorMode.Custom:
default:
break;
bool useMovingAverage;
/// <summary>
/// Controls whether the system uses moving averages to smooth out values.
/// This should be True if you have a high speed update, or are movement is slow.
/// This should be False if you are moving fast or have a slow update rate.
/// Moving averages introduce some lag into the system, therefore it's only useful with high update speeds or slow movements.
/// The moving average can take out spikes and other crazy phenomenon efficiently.
/// </summary>
public bool UseMovingAverage
get { return useMovingAverage; }
set
if (useMovingAverage == value)
return;
useMovingAverage = value;
if (useMovingAverage == true)
movingValues = new double[movingAverageSize];
movingPos = 0;
int movingAverageSize;
/// <summary>
/// Gets/Sets the size of the moving average set. If the set is too large, there will be considerable lag. If the set is too small, it will be inefficient.
/// </summary>
public int MovingAverageSize
get { return movingAverageSize; }
set
if (movingAverageSize == value)
return;
movingAverageSize = value;
movingPos = 0;
private bool useFiltering;
/// <summary>
/// Gets/Sets whether standard deviation filtering should be used. This only works with UseAveraging turned on.
/// If values read have too wide of a range, anything beyond one standard deviation will be culled and ignored.
/// If you have high speed movement, this will get a good workout and may not be of any benefit.
/// If you have slow movement with a lot of 'noise' this will clean it up considerably.
/// </summary>
public bool UseFiltering
get { return useFiltering; }
set
if (value && !UseAveraging)
throw new NotSupportedException("You cannot use filtering without averaging!");
useFiltering = value;
/// <summary>
/// When using averaging, the sensor will take <c>AverageSampleCount</c> samples and then average them to remove some fluctuations.
/// This works very well at all times and should be left on, vary the sample count based on the speed of code you require, and the speed you move at.
/// </summary>
public bool UseAveraging { get; set; }
/// <summary>
/// Gets/sets the number of samples to take for averaging.
/// </summary>
public int AverageSampleCount { get; set; }
#region IDisposable Members
public void Dispose()
sensor.Dispose();
#endregion
/// <summary>
/// The maximum Current (in amps) that the senor can sense.
/// </summary>
public float MaximumCurrentCapability { get; protected set; }
/// <summary>
/// The minimum current (in amps) that the sensor can sense.
/// </summary>
public float MinimumCurrentCapability { get; protected set; }
