hello, Please help me
My problem is that EMX development system read 8 byte in the time when I send a string of 30 byte ie :
an exemlple:
I am sending a message “1, 12.42 .12,121,45556854.12\n” from PC
I receive the in EMX development system 8 byte cad "z, 12.42."
my prbplem in the line 15 : int count = UART.Read(rx_byte, 0, 60);///// MY PROBLEM IS (count = 8)
here is my code:
namespace change_this_to_your_namespace
SerialPort UART = new SerialPort("COM2", 9600);
int read_count = 0;
byte[] rx_byte = new byte[60];
UART.Open();
int count = UART.Read(rx_byte, 0, 60);///// MY PROBLEM IS HERE (count = 8) when I send "z,12.42,12,121,45556854.12\n" read 8 byte(z,12.42,)
if (count > 0) // Minimum one byte read
char[] chars = Encoding.UTF8.GetChars(rx_byte);
string dataLine = new string(chars, 1, count);
string[] tram = dataLine.Split(',', '\n'); // parse the NMEA data sentence here
int l = tram.Length;
// int type =(int) ConvertString.ToSingle(tram[0]);
int type = (int)double.Parse(tram[0]);
// float num = (int) ConvertString.ToSingle(tram[1]);
// float val_0 = ConvertString.ToSingle(tram[2]);
// float val_1 = ConvertString.ToSingle(tram[3]);
// float val_2 = ConvertString.ToSingle(tram[4]);
switch (type)
{ case 1 :
double ax = double.Parse(tram[2]);
double ay = double.Parse(tram[3]);
double az = double.Parse(tram[4]);
System.Console.WriteLine("ax=" + ax + " " + "ay=" + ax + " " + "az=" + az);
break;
case 11 :
double Gx = double.Parse(tram[2]);
double Gy = double.Parse(tram[3]);
double Gz = double.Parse(tram[4]);
System.Console.WriteLine("Gx=" + Gx + " " + "Gy=" + Gy + " " + "Gz=" + Gz);
break;
case 2 :
double Mx = double.Parse(tram[2]);
double My = double.Parse(tram[3]);
double Mz = double.Parse(tram[4]);
System.Console.WriteLine("Mx=" + Mx + " " + "My=" + My + " " + "Mz=" + Mz);
break;
case 3:
double Rx = double.Parse(tram[2]);
double Ry = double.Parse(tram[3]);
double Rz = double.Parse(tram[4]);
Console.WriteLine("Rx=" + Rx + " " + "Ry=" + Ry + " " + "Rz=" + Rz + " ");
break;
case 95 :
double H = double.Parse(tram[2]);
double M = double.Parse(tram[3]);
double S = double.Parse(tram[4]);
System.Console.WriteLine("H=" + H + " " + "M=" + M + " " + "S=" + S + " ");
break;
case 98:
double lat = double.Parse(tram[2]);
double latVirgule = double.Parse(tram[3]);
int n = (tram[3].Length);
lat = lat + latVirgule / Math.Pow(10, n);
double log = double.Parse(tram[4]);
double logVirgule = double.Parse(tram[5]);
int m = (tram[5].Length);
log = log + latVirgule / Math.Pow(10, m);
double alt = double.Parse(tram[6]);
System.Console.WriteLine("lat=" + lat + " " + "log=" + log + " " + "alt=" + alt + " ");
break;
case 199:
if (l ==8)
double bering = double.Parse(tram[2]);
double beringVirgule = double.Parse(tram[3]);
int m1 = (tram[3].Length);
bering = bering + beringVirgule / Math.Pow(10, m1);
double speed = double.Parse(tram[4]);
double speedVirgule = double.Parse(tram[5]);
int n1 = (tram[5].Length);
speed = speed + speedVirgule / Math.Pow(10, n1);
double time = double.Parse(tram[l - 2]);
System.Console.WriteLine("speed=" + speed + " " + "bering=" + bering + " " + "time =" + time + " ");
double speed = 0;
break;
