So for those who already has experience of making this two work together, what would be the best way of doing it? What code or libraries would be needed?
But when I run the downloaded demo, it shows this two errors.
Error 2 GenerateResource.ReferencedAssemblyNotFound - C:\Users\Robert\Desktop\ITDB02Demo\ITDB02\bin\Debug Netduino\ITDB02.dll: Could not load file or assembly ‘ITDB02.dll’ or one of its dependencies. The system cannot find the file specified.
Parameter name: C:\Users\Robert\Desktop\ITDB02Demo\ITDB02\bin\Debug Netduino\ITDB02.dll ITDB02Demo
Error 1 The type or namespace name ‘SecretLabs’ could not be found (are you missing a using directive or an assembly reference?) C:\Users\Robert\Desktop\ITDB02Demo\ITDB02\ITDB02.cs 10 7 ITDB02
Another thing, whenever I connect the LCD to Panda, USBizi dissapears from found hardware, therefor I can’t install anything onto it. :
First thing you need to do is remove the LCD from Panda and make sure they are the same pinout before you try it. I am 99% sure they are not the same pinout.
You can still do some wiring to make it work.Use the code GHI provides for FEZ Touch.
Roger, everything is in the attached zip. The error you are getting is because you are building Netduino version. Select non netduino target in the visual studio and try again.
