I got one FEZ Music Shield http://www.ghielectronics.com/catalog/product/289 and the overview states: [italic]Few simple lines of code are plenty enough to play music from SD cards, USB memory stick or even stream audio over the network[/italic].
Can someone please supply me with a simple working example on how to play a normal 4Mb MP3 file from my FEZ Domino SD card?
Not completely. The example only streams a small file that has been preloaded from resources. I need an example of reading a normal size MP3 file from an SD card.
Do you know how to read files from SD? GHI Electronics – Where Hardware Meets Software
If so, all you need is this
while(file is not done)
ReadFromSD(…);
WriteTo MusicShield(…);
This is what I have tried
static MusicShield musicShield = new MusicShield(SPI.SPI_module.SPI1, FEZ_Pin.Digital.An4, FEZ_Pin.Digital.An5, FEZ_Pin.Digital.Di4);
PersistentStorage sd = new PersistentStorage("SD");
sd.MountFileSystem();
PlayStatement("1.mp3");
Thread.Sleep(1000);
public static void PlayStatement(string FileName)
int offset = 0;
byte[] data = new byte[10 * 1024];
musicShield.SetVolume(240, 240);
FileStream fs = new FileStream("\\SD\\" + FileName , FileMode.Open, FileAccess.Read);
fs.Seek(offset, SeekOrigin.Begin);
int bytesRead = 0;
bytesRead = fs.Read(data, 0, data.Length);
while (bytesRead != 0)
musicShield.Play(data);
while (musicShield.IsBusy) Thread.Sleep(10);
fs.Close();
fs.Dispose();
fs = null;
It plays the file… sort of. But there is a small glitch in the sound output when new data is read, so the quality is crap. How to fix this?
did you tried using a smaller buffer?
What is the bit-rate of the file you are playing? Lower bit-rate will make things a lot easier.
Also, if I remember correctly the internal buffer of the MP3 chip is 32bytes or something really small so reading 1K data maybe to long of a delay to the MP3 chip. Use smaller buffer like Eric suggested.
Ok so I tried a lower bitrate 160kbps (the shield overview doesnt say anything about bitrate limitations). That did not help.
I tried with a buffersize from 16byte, 32byte, 512byte of 1k and got absoluttly nothing out of the speakers.
Tried with a buffer of 5k got some very copped up ugly sound.
With a 10k buffer Im able to hear what song it is, -but still crap (lots of chopping).
I found an example that seems to work http://code.tinyclr.com/project/344/music-shield-extension-playing-streams/
But I cant figure out this line
musicShield.OnPlaybackStopped += new GHIElectronics.NETMF.FEZ.Shields.MusicShield.PlaybackStopped(musicShield_OnPlaybackStopped);
The compiler states: The name ‘musicShield_OnPlaybackStopped’ does not exist in the current context
Is there something missing in the example?
Geir,
delete everything starting from +=, add again += and press tab twice.
Visual studio adds the missing code for you when you do the above.
Yes it works now.
Thanks for your help.
