Finally got Raspberry Pi 2 set up with windows 10 and connected to bread board to play with electronics ![]()
This is actually monitoring a build server.
Behind it all, a process in the cloud is scanning Jenkins jobs and updating a SQL database. An ASP.net website is then offering a WebApi 2 view of the build job data which this program uses.
And whats more all the code is in VB (Finally fully supported in Universal apps
' The Blank Page item template is documented at http://go.microsoft.com/fwlink/?LinkId=402352&clcid=0x409
Imports Newtonsoft.Json
Imports Windows.Devices.Gpio
Imports Windows.Web.Http
''' <summary>
''' An empty page that can be used on its own or navigated to within a Frame.
''' </summary>
Public NotInheritable Class MainPage
Inherits Page
' Private Class Declrations
Private LEDStatus As Integer = 0
Private Const RED_LED_PIN As Integer = 5
Private Const YELLOW_LED_PIN As Integer = 6
Private Const GREEN_LED_PIN As Integer = 13
Private red_pin As GpioPin
Private yellow_pin As GpioPin
Private green_pin As GpioPin
Private redBrush As SolidColorBrush = New SolidColorBrush(Windows.UI.Colors.Red)
Private yellowBrush As SolidColorBrush = New SolidColorBrush(Windows.UI.Colors.Yellow)
Private greenBrush As SolidColorBrush = New SolidColorBrush(Windows.UI.Colors.Green)
Private _timer As DispatcherTimer
Private _flasher As DispatcherTimer
Private _currentFlashStatus As Boolean = False
Public Sub New()
' This call is required by the designer.
InitializeComponent()
InitGPIO()
AddHandler Me.Unloaded, AddressOf MainPage_Unloaded
' Add any initialization after the InitializeComponent() call.
_timer = New DispatcherTimer
_timer.Interval = TimeSpan.FromSeconds(10)
AddHandler _timer.Tick, AddressOf Timer_Tick
_timer.Start()
_flasher = New DispatcherTimer
_flasher.Interval = TimeSpan.FromMilliseconds(250)
AddHandler _flasher.Tick, AddressOf Flasher_Tick
GetBuildStatus()
End Sub
Private Sub Flasher_Tick(sender As Object, e As Object)
If _currentFlashStatus = False Then
AllOn()
_currentFlashStatus = True
Else
AllOff()
End If
End Sub
Private Sub Timer_Tick(sender As Object, e As Object)
GetBuildStatus()
End Sub
Private Sub MainPage_Unloaded(sender As Object, e As RoutedEventArgs)
red_pin.Dispose()
yellow_pin.Dispose()
green_pin.Dispose()
End Sub
Private Sub InitGPIO()
Dim gpio = GpioController.GetDefault
' Show error if there is no GPIO Controller
If gpio Is Nothing Then
red_pin = Nothing
yellow_pin = Nothing
green_pin = Nothing
GpioStatus.Text = "There is no GPIO Controller on this device."
Exit Sub
End If
red_pin = gpio.OpenPin(RED_LED_PIN)
yellow_pin = gpio.OpenPin(YELLOW_LED_PIN)
green_pin = gpio.OpenPin(GREEN_LED_PIN)
' Show error is the pin wasn't initialised properly
If red_pin Is Nothing Or yellow_pin Is Nothing Or green_pin Is Nothing Then
GpioStatus.Text = "There were problems initalising the GPIO pins."
Exit Sub
End If
red_pin.Write(GpioPinValue.High)
red_pin.SetDriveMode(GpioPinDriveMode.Output)
yellow_pin.Write(GpioPinValue.High)
yellow_pin.SetDriveMode(GpioPinDriveMode.Output)
green_pin.Write(GpioPinValue.High)
green_pin.SetDriveMode(GpioPinDriveMode.Output)
GpioStatus.Text = "GPIO Pins initialised correctly."
End Sub
Public Sub SetMode(status As BuildStatus)
Dim pin As GpioPin
Dim brush As SolidColorBrush
Select Case status
Case BuildStatus.Failed
pin = red_pin
brush = redBrush
Case BuildStatus.Passed
pin = green_pin
brush = greenBrush
Case Else
pin = yellow_pin
brush = yellowBrush
End Select
If status = BuildStatus.Running Then
_flasher.Start()
Else
_flasher.Stop()
AllOff()
If pin IsNot Nothing Then
pin.Write(GpioPinValue.Low)
End If
LED.Fill = brush
End If
End Sub
Public Sub AllOff()
End Sub
Public Sub AllOn()
red_pin.Write(GpioPinValue.Low)
yellow_pin.Write(GpioPinValue.Low)
green_pin.Write(GpioPinValue.Low)
End Sub
Public Async Sub GetBuildStatus()
Dim client As New HttpClient
Dim jobs As New List(Of BuildJob)
Try
Dim result = Await client.GetStringAsync(New Uri("http://mybuildserver.com/api/BuildStatus?ModuleName=Master Build"))
'GpioStatus.Text = result
jobs = JsonConvert.DeserializeObject(Of List(Of BuildJob))(result)
Catch ex As Exception
GpioStatus.Text = ex.Message
Exit Sub
End Try
If jobs(0).JobIsRunning = True Then
jobs(0).CurrentStatus = "running"
End If
Dim status As BuildStatus
Select Case jobs(0).CurrentStatus
Case "running"
Case "success"
status = BuildStatus.Passed
Case "failure"
status = BuildStatus.Failed
Case Else
status = BuildStatus.Error
End Select
SetMode(status)
End Sub
End Class
Canβt wait till I can plug in Gadgetter devices.
