I finally decided to try doing something with the PixyCam. It’s been kicking around in my office for over a year.
I find the documentation for Pixy to be quite poor relying mainly on Arduino code examples.
This port is using the SPI Interface but means that the functionality is limited as the full API is only available via USB.
There’s still a lot of tweaking to do as this is just a port of the Arduino at present and the PID Terms are set deliberately slow and far from optimal but at least I’m getting block data back and can drive the LED and servo pins.
ps - Please ignore the state of my desk - it’s a man cave. :-[
Great work, are you going to make a driver or share the snippet? I’ve been searching for this for months as I couldn’t get my pixy to communicate with a raptor.
Sounds great. I’ve been trying to do the same thing all day today. I’ve created a cable that works, and got the Raptor talking over SPI to the Pixycam/CMUcam5. I’ve modified the Arduino code and it ‘works’ to some extent. However, while I do see data coming from the cam (I cover the lens an I get no data, I uncover it and I get data), but I don’t get a start of frame or block marker (AA 55 hex or 170 85 decimal). When I use PixyMon on my PC, I see an object detected and its signature 1. On the Raptor I do get bytes 170 170 regularly and here’s an example of the bytes that follows, any ideas???
Sorry guys but I’m currently stuck on a project for the boss (the wife in other words) so haven’t been able to refine the code.
From my initial trials I started to think that the SPI interface wasn’t the best way to go with this as the usb interface would really open up more possibilities but is currently way outside my comfort zone.
So, I finally got it working, using SPI! Although I was getting data through I could not find the frame start marker, but when I changed the clock idle state flag from false to true, I get good data!
I will post full code once I get all the bugs ironed out (hopefully this week), but in the meantime, the code to create the SPI is this…
public PixyCam(int socketNumber)
//raptor sockets 1,3, 11 support spi
Socket spiSocket = Socket.GetSocket(socketNumber, true, this, null);
spiSocket.EnsureTypeIsSupported('S', this);
SPI.SPI_module spiModule = spiSocket.SPIModule;
SPI.Configuration PixyCamSPIConfig = new SPI.Configuration(
Cpu.Pin.GPIO_NONE, //chip select port - not required for ICSPI like Arduino no slave select
false, //chip select active state - If true, the chip select port will be set to high when accessing the chip; if false, the chip select port will be set to low when accessing the chip
0, //chip select setup time - amount of time that will elapse between the time at which the device is selected and the time at which the clock and the clock data transmission will start
0, //chip select hold time - specifies the amount of time that the chip select port must remain in the active state before the device is unselected
true, //clock idle state - If true, the SPI clock signal will be set to high while the device is idle; if false, the SPI clock signal will be set to low while the device is idle
true, //clock edge - If true, data is sampled on the SPI clock rising edge; if false, the data is sampled on the SPI clock falling edge
1000, //clock kHz (1mhz) - 1000=1Mhz sampling rate
spiModule //SPI module defined above
SPI PixyCamSPI = new SPI(PixyCamSPIConfig);
