PIR module education
Hello,
I’m trying to understand the mechanics of the PIR module. I’ve read pdf files and played with the pots but I still am not clear why the Motion_Sensed is firing every few seconds, without any motion.
thanks
Mike
Hi mikef and welcome to the community.
What main board are you using?? I have two PIR modules, one which works fine and one that ONLY works on a spider. On any other mainboard it fires every six seconds (which follows the time set with one of the pots)
No real solution as far as i have found yet. GHI aren’t seeing the problem and ive been trying to diagnose the issue but no joy yet.
There are a number of topics on this very subject.
@ HughB - Hate to say it but i have a GHI module and it plays nice - no 6 second premature…
hahaha - its wierd both of mine behave differently.
Thanks guys,
I’m seeing the same behaviour on the spider and cerberus. I’ll try it on the Bee but I’m thinking I’ll see the same issue.
Mike
same here… i just starting playing with it and it fires regardless of the ped 2 (proximity) setting. do i just have a bad module or is the issue something else? good thing i didn’t order 3 more.
@ carpenoctem - What mainboard are you using?
Spider with latest firmware
