Hello! I have a Fez Hydra, but Windows 7 still detects FEZ Hydra as a “.NET Debug device” .
As described in
I erased the flash. After this step Win 7 detected Fez Hydra as GPS Device on Com Port 5. Okay…
But after the next stept (Loading Bootstrap) Win 7 detected Fez Hydra as a “.NET Debug device” again.
MFDeploy 4.1 found FEZ Hydra_Gadgeteer (and not FEZ Hydra_FEZHydra as described). And the ping command never cpmes back… ;(
You must stop the VMWare USB Arbitration service to talk to the Hydra until a bug fix is released in the next SDK. THis service is on regardless of whether you are using a VM or not.
There is a fix for the Ping issue that you are experiencing using VMWare. For the computers running VMUSBArbService, it forces the Hydra into a endless loop. This issue is fixed in the soon to be released SDK.
