PIezo on Cobra question
I am a bit confused on using the piezo on the Corbra board.
It is connected to IO10, but that is not a PWM pin.
From some searching i have done, using the piezo uses the PWM and i should use .Play for it.
So how do i get the piezo to make sound on the Corbra since it not connected on a PWM pin?
Thanks.
There is dedicate piezo method in Utilities class
yes, but how do you configure the pin ?
its confusing to me, as some examples use PWM, yet its not a PWM pin.
Just call that method, nothing to configure
Dam, that was easy!!
but what if i want a tone constantly.
OutputCompare?
