PICO data logging SD micro card
Interested in data logging with PICO board. Description of PICO says it works with PICO accessories, and I have two questions:
  1. Is there a list of Pico Accessories somewhere, like an SD Micro card?
  2. Are there any code examples to do data logging to an SD card with the PICO?
Thanks in advance,
Rocky
Boards that are based on SC13 does not have full FAT file system support but you can use TinyFile System File System
If you need proper SD support then use a FEZX board with SD card, from the SC20 family.
