I wonder whether anyone has solved this problem that I’m currently struggling with:
I would like to use some Dominos / Pandas in a small run of say a dozen prototypes. These need to have prototype cases also. My current case design has enough room for 3 x arduino size boards (side-by-side rather than on top of each other) and a display etc (see image attached). The problem is the usb port which I would like to bring to the outside.
One option is to just position the existing usb port near the case wall and have a hole in the right place. But, I would rather not design the whole case around the arbitrary position of the usb port
Anyone else had the same problem? Has anyone unsoldered the usb connector from these boards and substituted a flying lead to a panel mounted usb port? Are there any other creative options I’m missing?
Thanks,
Alan
